bios for HP EliteBook x360 1030 G2
  • peste
    • 13451
    • ROMANIA
    #61
    Re: hp elitebook x360 1030 G2 BIOS!!
    Originally posted by 2taou.fik.58
    Hello, I've recently purchased a second-hand laptop.
    The previous owner did not tell me that the laptop has a BIOS password.
    After some research, I've successfully dumped the laptop's BIOS .bin file (16 MB).
    Here it is, could you please try and see if you can do anything to remove the password?
    Thank you very much.
    your bios is half empty .. read your bios again but remove the chip from the motherboard,after you have a verified and correct copy of the bios, you can write the chip with the bios from item # 2 and 4.
    try this one too..
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      #62
      Logic error? Can't read again if it is overwritten with another dump.
      First try to get a correct dump, then start trying other files.
      • piernov
        • Jan 2016
        • 4437
        • France
        #63
        Agreed. Get a good dump BEFORE trying to write anything. Otherwise you will brick the machine.
        • peste
          • 13451
          • ROMANIA
          #64
          you are right..I was not careful...well you have seen ..
          I modified it because I thought I would not read the following posts ...
          • kingnizarios
            • Apr 2020
            • 21
            • Tunisie
            #65
            Please i need to unlock bios of an x360 1030 g2
            hi
            i need help to unlock the bios of an hp elite book x360 1030 g2
            i m in trouble cause i flash a bios from another computer and now the computer keep blinking.
            this is the orginal dump attached it need to be cleared.
            please help.
            • lapfix
              • Mar 2020
              • 2756
              • my workshop
              #66
              Re: Please i need to unlock bios of an x360 1030 g2
              Try and give feedback
              • kingnizarios
                • Apr 2020
                • 21
                • Tunisie
                #67
                think you you are genious can you give me the methode
                • lapfix
                  • Mar 2020
                  • 2756
                  • my workshop
                  #68
                  i'm not but thank you , methode = you will find it here in this forum ...chahia tayba
                  • kingnizarios
                    • Apr 2020
                    • 21
                    • Tunisie
                    #69
                    thanks
                    • Fuzer
                      • Jun 2015
                      • 11
                      • Portugal
                      #70
                      Re: HP EliteBook x360 1030 G2 dump urgent
                      I there
                      I have one HP EliteBook x360 1030 G2 that the screen does not have backlight. The pc boots normaly but when i changed the screen, because the old one cracked, the screen backlight stopped working.
                      I have the chance to buy a used motherboard with bios locked supposedly working properly, can i copy the dump of the Bios of the old working and program the locked Bios with that dump? Since it has 2 ic chips, which one should i copy?
                      Appreciate the help in this subject.
                      Compliments
                      • MAZMAZ22
                        • Jul 2016
                        • 68
                        • ALGERIE
                        #71
                        Re: UNLOCK BIOS PASSWORD HP EliteBook x360 1030 G2
                        Hi need to clear password
                        • peste
                          • 13451
                          • ROMANIA
                          #72
                          The bios posted here is not by Elitebook, it is by Spectre Pro x360 G2.
                          try bid 08197
                          https://www.badcaps.net/forum/showth...545#post966545
                          • RethoricalCheese
                            • Mar 2013
                            • 1519
                            • Estonia
                            #73
                            Your password seems to be fat2q
                            • SebastienM
                              • Jun 2020
                              • France
                              #74
                              Hello !
                              I have an HP Elibook x360 1030 G2 which is blocked at the bios level.
                              I wanted to dump the blocked bios but neither Universal BIOS Backup ToolKit 2.0 nor De-CMOS3 works.
                              Do you have other programs to dump the bios?
                              Thank you !
                              • piernov
                                • Jan 2016
                                • 4437
                                • France
                                #75
                                You need an external programmer. You won't be able to flash back the stuff that needs to be modified otherwise.
                                • djserhatcom
                                  • Jun 2015
                                  • 14
                                  • avcılar
                                  #76
                                  Re: HP EliteBook x360 1030 G2...help
                                  Can you remove the password please
                                  https://yadi.sk/d/uJjFzyTs2eDecg
                                  • peste
                                    • 13451
                                    • ROMANIA
                                    #77
                                    try..
                                    • djserhatcom
                                      • Jun 2015
                                      • 14
                                      • avcılar
                                      #78
                                      thank you so much. worked. We would appreciate it if you explain how to remove password.
                                      • peste
                                        • 13451
                                        • ROMANIA
                                        #79
                                        https://www.badcaps.net/forum/showthread.php?t=79956
                                        • Fuzer
                                          • Jun 2015
                                          • 11
                                          • Portugal
                                          #80
                                          HP Elitebook x360 1030 G2
                                          I there
                                          I have a problem with the motherboard of this notebook.
                                          When i connect the power supply the power supply LED blinks 7 times, i was researching for this problem and found that this is a BIOS related problem.
                                          Then i flashed the Bios with a CH341 programmer and soldering tho the motherboard and still the same problem.
                                          Does anyone had similar problem or possible solution?
                                          note: I flashed the 128Mb bios, could the problem be on the other bios chip?
                                          Compliments
                                            HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 boardview and EliteBook x360 1030 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:27 AM
                                            HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 (ENERGY STAR) boardview and EliteBook x360 1030 G2 (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 06:40 AM
                                            09-06-2024, 05:33 AM
                                            HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EquipoEliteBook x360 1030 G4 boardview and EquipoEliteBook x360 1030 G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            09-06-2024, 11:32 AM
