Asus ROG GL502VM G502VM Bios
  • JLCurve
    • Feb 2017
    • 32
    HI,
    Looking for bios image for the GL502VM (NOT the GL502VMK).
    Also, I'm a bit puzzled, there are 3 serial flash chips on this motherboard. Which one(s) are the bios?
  • angel-boy
    • 550
    • Romania
    Re: Asus ROG GL502VM G502VM Bios
    Mainboard name, and revision
    • JLCurve
      • Feb 2017
      • 32
      GL502VM
      Rev 2.0
      • angel-boy
        • 550
        • Romania
        try this
        • JLCurve
          • Feb 2017
          • 32
          Thank, I will do try.
          Onlly one chip is 64Mb so no confusion after all.
          Any idea what are the other two 8Mb chips? ... just curious.
          • angel-boy
            • 550
            • Romania
            Try to replace only W25Q64 , if not , let me know to search for all
            tell me the name of other 2 cip
            • JLCurve
              • Feb 2017
              • 32
              The two other chips are W25Q80.
              One of your files was the correct bios file. Thank you!
              But I still have weird blue screens in Windows 10. On the other hand, Ubuntu seems to run without problems. Will try to reinstall Win10.
              J.
              • angel-boy
                • 550
                • Romania
                See if the hard drive operating system is legacy or uefi ,
                • AlvaroGuerrero
                  • Aug 2018
                  • 3
                  Originally posted by JLCurve
                  HI,
                  hey was just wondering what number(in your photo) was the correct chip
                  • zommify
                    • Jun 2019
                    Is it possible to get a dump of the W25Q80. Sorry if I'm necroing a dead thread.
                    • Zeeshanali1
                      • Oct 2018
                      • 27
                      • Pakistan
                      i need accurate bios GL502vm rev 2.1
                      but i have an issue display driver did not install.......
                      i have try many time ..
                      zash
                      • balobi
                        • Jan 2015
                        • 88
                        • phillippines
                        Angel_boy, thanks! Working bin files.
                        • enricora
                          • Sep 2015
                          • italy
                          tanks! the ver GL502VM REV 2.1.zip have restore my bricked gl502vm.
                          very nice forum
                          • dumikosma
                            • Mar 2020
                            • Belgia
                            I do confirm that GL502VM REV2.1 is ok ; it save my laptop as wel . Thanks
                            • MISICO
                              • Jun 2021
                              • Ecuador
                              Hello, I hope you can help me, I am presented with a keyboard problem on my computer, this is a GL502VM and it has the Bios driver GL502VMK.308 installed, I try to install the bios that I downloaded from this forum but I do not have the option available in the BIOS ez flash 3 utility (it is off, it does not appear highlighted), I try to install it by the asus driver installer for windows 10 and it tells me that it is not compatible (it recognizes the GL502VMK> 308) and it does not let me go to an older driver How do I install the correct driver? Thank you
                              • ashefr10
                                • Mar 2021
                                • 11
                                • France
                                HELLO I search a full dump bios for G502VM With motherboard v2.0
                                (with ch341A programer spi) with backlight keyboard and me firmware please . (8mb)
                                • binoyroy
                                  • Sep 2017
                                  • 51
                                  • bangladeah
                                  [QUOTE=ashefr10;1198541]HELLO I search a full dump bios for G502VM With motherboard v2.0
                                  Try this
                                  • ashefr10
                                    • Mar 2021
                                    • 11
                                    • France
                                    [QUOTE=binoyroy;1198591]
                                    Try this
                                    hello, thank you this bios works the ME part no longer has the error at startup but I do not have the backlight of the keyboard
                                    backlight keyboard not work
                                    • ashefr10
                                      • Mar 2021
                                      • 11
                                      • France
                                      I need a complete bios where the backlight works as well as the ME part
                                      • peste
                                        • Dec 2016
                                        • 12748
                                        • ROMANIA
                                        try.this..
                                        https://www.badcaps.net/forum/showthread.php?t=69782
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • lrouw84
                                          by lrouw84
                                          Hi there,
                                          01-28-2023, 01:31 PM
