Dump MIO(kbc) LA-C292P
  • husniddin
    • Jan 2017
    • 98
    • Uzbekistan
    Hello, friends who has dump mio (kbc) npce388na1dx for lenovo b51-30 motherboards la-c292p
    thanks.
  • imranromi
    • Jan 2015
    • 1292
    • Pakistan
    Re: Dump MIO(kbc) LA-C292P
    thanks.
    you have a old ec?post here.
    • husniddin
      • Jan 2017
      • 98
      • Uzbekistan
      backup kbc la-c292p
      • imranromi
        • Jan 2015
        • 1292
        • Pakistan
        backup kbc la-c292p
        Try this.
        • andrew25
          • Feb 2016
          • 224
          • Malawi
          I need bios dump for that model
          • andrew25
            • Feb 2016
            • 224
            • Malawi
            I need bios dump if you have
            • imranromi
              • Jan 2015
              • 1292
              • Pakistan
              You have old dump post here.
              • husniddin
                • Jan 2017
                • 98
                • Uzbekistan
                try this
                • mbertaina
                  • Jun 2016
                  • 7
                  • Argentina
                  try this
                  You are a genius! Thanks work
                  • mohamedbalwe
                    • Jan 2021
                    • 54
                    • aleppo
                    hello are you can help me
                    i need for pin code to programer io same model board
                    • mohamedbalwe
                      • Jan 2021
                      • 54
                      • aleppo
                      try this
                      sir i need pin code to set in pragram vertynaov
                      • mohamedbalwe
                        • Jan 2021
                        • 54
                        • aleppo
                        any one help me
                          • 22279
                          Originally posted by mohamedbalwe
                          any one help me
                          Does the connector have 30 pins or 26
                          STANDART_1pin_LEFT KB_pins=30 1MM LEFT DOWN JENK=7 TCK=19 TMS=20 TDI=21 TDO=10
                          • mohamedbalwe
                            • Jan 2021
                            • 54
                            • aleppo
                            thanks sir
                            • Ahari
                              by Ahari
                              I...
                              08-13-2025, 06:12 AM
                            • mkdj
                              by mkdj
                              Dear all,
                              10-19-2025, 04:41 AM
                            • Habble7
                              by Habble7
                              Suspected Cause:
                              Troubleshooting Attempts:
                              05-22-2025, 07:28 AM
                            • Mephysis
                              DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                              by Mephysis
                              Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                              I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                              03-27-2025, 02:34 AM
                            • dell_bios
                              Need unlocked BIOS dump for W25Q64FV (Admin Password removal)
                              by dell_bios
                              I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
                              The board has three SPI flash chips:
                              - W25Q64FV (main BIOS)
                              - W25Q32FV (EC/TPM)
                              - W25X10CL (configuration)
                              I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
                              The dump contains protection that needs to be removed.
                              If anyone has a clean or unlocked BIOS dump for W25Q64FV, I’d really appreciate it!
                              I’m also happy to share my dump for comparison if needed.
                              Laptop model: [please specify, e.g....
                              10-16-2025, 04:28 PM
