Dump MIO(kbc) LA-C292P
  • husniddin
    • Jan 2017
    • 98
    • Uzbekistan
    Hello, friends who has dump mio (kbc) npce388na1dx for lenovo b51-30 motherboards la-c292p
    thanks.
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: Dump MIO(kbc) LA-C292P
    thanks.
    you have a old ec?post here.
    • husniddin
      • Jan 2017
      • 98
      • Uzbekistan
      backup kbc la-c292p
      • imranromi
        • Jan 2015
        • 1288
        • Pakistan
        backup kbc la-c292p
        Try this.
        • andrew25
          • Feb 2016
          • 220
          • Malawi
          I need bios dump for that model
          • andrew25
            • Feb 2016
            • 220
            • Malawi
            I need bios dump if you have
            • imranromi
              • Jan 2015
              • 1288
              • Pakistan
              You have old dump post here.
              • husniddin
                • Jan 2017
                • 98
                • Uzbekistan
                try this
                • mbertaina
                  • Jun 2016
                  • 7
                  • Argentina
                  try this
                  You are a genius! Thanks work
                  • mohamedbalwe
                    • Jan 2021
                    • 49
                    • aleppo
                    hello are you can help me
                    i need for pin code to programer io same model board
                    • mohamedbalwe
                      • Jan 2021
                      • 49
                      • aleppo
                      try this
                      sir i need pin code to set in pragram vertynaov
                      • mohamedbalwe
                        • Jan 2021
                        • 49
                        • aleppo
                        any one help me
                          • 20479
                          Originally posted by mohamedbalwe
                          any one help me
                          Does the connector have 30 pins or 26
                          STANDART_1pin_LEFT KB_pins=30 1MM LEFT DOWN JENK=7 TCK=19 TMS=20 TDI=21 TDO=10
                          • mohamedbalwe
                            • Jan 2021
                            • 49
                            • aleppo
                            thanks sir
                            • Habble7
                              by Habble7
                              Suspected Cause:
                              Troubleshooting Attempts:
                              05-22-2025, 07:28 AM
                            • Mephysis
                              DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                              by Mephysis
                              Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                              I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                              03-27-2025, 02:34 AM
                            • hyperwood
                              [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                              by hyperwood
                              I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                              The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                              I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                              āœ… What I need:
                              • A working 2MB BIOS dump
                              • Matching NM-E471 Rev. 2.0, e.g. JY575
                              06-25-2025, 02:28 PM
                            • Andreas_de
                              Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                              by Andreas_de
                              Hello!
                              i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                              Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                              Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                              04-12-2025, 10:38 AM
                            • re-atari
                              Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
                              by re-atari
                              Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
                              Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
                              02-03-2025, 06:49 PM
