hp dv7 1285dx bios needed
  • String2016
    • Nov 2015
    • 2242
    • philippines
    Hi everyone i need help on this HP DV7 1285DX, i made mistake after i update the bios the laptop now turns on but no display, at first it is working fine i tried updating the bios due to battery not charging.i made mistake i did not notice i downloaded the update on hp site when i flash using INSYDE the original id 30F4 and i flashed with the wrong one 30F3.does anyone have a working bios for this please,
  • imranromi
    • Jan 2015
    • 1292
    • Pakistan
    Re: hp dv7 1285dx bios needed
    old bios send.and send board code.
    • String2016
      • Nov 2015
      • 2242
      • philippines
      the problem i haven't back up the old bios because laptop is working fine then i update the bios with i downloaded on hp site , and i havent noticed the id and reflashed with wrong one now the laptop turns on but no display
      • imranromi
        • Jan 2015
        • 1292
        • Pakistan
        try this.
        • String2016
          • Nov 2015
          • 2242
          • philippines
          ok thanks ill try this
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            always backup your bios even if its not working
            there are usefull information in it
            here is every bios for that model (3 version of motherboard, 3 bios)
            Im Back... sort of...
            • String2016
              • Nov 2015
              • 2242
              • philippines
              thanks its working but need to fix DMI
              • mikeybass
                by mikeybass
                04-23-2025, 04:30 PM
              • akwky
                by akwky
                Hi!
                04-14-2025, 01:56 PM
              • tlindi
                Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                by tlindi
                Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                Ack
                Ack
                01-30-2025, 04:26 AM
              • al3m0di
                Update bios EFCN58WW to EFCN59WW
                by al3m0di
                Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                The BIOS version is EFCN58WW.
                When I turn on the device, it displays the message:
                "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                I've tried
                07-29-2024, 10:32 AM
              • capoplays
                Help with BIOS update on Dell G15 5515 after chip replacement
                by capoplays
                Hey everyone,
                I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                When I check the BIOS using the F12 menu Flash...
                10-24-2025, 06:53 AM
