Remove_SMM... UEFI.
Re: Remove_SMM... UEFI.
try this file and valid with any keyAttached FilesComment
I am new to this. So if i want to reflash bios to remove the password, I will need the original bios dump? I cannot just rewrite the patched bin file that I can find here?
I have a T440 here. But unfortunately, the laptop was unable to power on after I program a patched T440.bin file that I got from here.Comment
This means I need the original bios dump. Then replace body for boot option and lenovotranslateservice using UEFItool, and then save a new image. After which I will reflash bios and I should be able to remove my bios lock right?Comment
1. Remove The Battery CMOS . Also make sure laptop's main battery is out and disconnect the internal front battery if used (many new Lenovo may have an internal battery, the black box) by removing its connector from the motherboard. It is important that the laptop will have NO The main Battery attached and the NO Battery CMOS .
2. Insert other LOCK HDD OR SSD M.2 ( by the way use another laptop set up password lock HDD and remember your password )
3. ReFlash BIOS with patched file
4. The First Step Let Press Down and Still Keep Little Switch ( picture attached ) long time and The Second Step Let Plug in the AC adapter and wait for a few seconds, the laptop will start by itself (if not, press the Power button and start it). You may hear some beeps then you will see the Lenovo splash image, press F1 to get the SVP password prompt and enter "1234" for SVP and press Enter. Next page will showing "Press any key..". Wait about 10 to 12 seconds before pressing any Key. Next it will display the warning message and the laptop hardware ID. Do not disconnect the AC during this process!Comment
1. Remove the battery cmos . Also make sure laptop's main battery is out and disconnect the internal front battery if used (many new lenovo may have an internal battery, the black box) by removing its connector from the motherboard. It is important that the laptop will have no the main battery attached and the no battery cmos .
2. Insert other lock hdd or ssd m.2 ( by the way use another laptop set up password lock hdd and remember your password )
3. Reflash bios with patched file
4. The first step let press down and still keep little switch ( picture attached ) long time and the second step let plug in the ac adapter and wait for a few seconds, the laptop will start by itself (if not, press the power button and start it). You may hear some beeps then you will see the lenovo splash image, press f1 to get the svp password prompt and enter "1234" for svp and press enter. Next page will showing "press any key..". Wait about 10 to 12 seconds before pressing any key. Next it will display the warning message and the laptop hardware id. Do not disconnect the ac during this process!
i did all steps you mentioned and i press 1234 and hardware id appeared after pressing enter i wait for moment message appear that security reset
and pressed power button then again on but laptop stuck
you can see the picture
thank youComment
. Now you need to press Space twice
. You can now power off the lenovo and reflash the original dumpComment
SEE THIS VIDEO https://www.youtube.com/watch?v=171_Wfm-e80
THANK YOU SO MUCHComment
Read this topic from the beginning to end and then try following instructions you found.Comment
by DynaxSCHi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent... -
by m3vuvIts a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
07-15-2024, 10:15 AM -
by CronaxFDHey guys,
Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
From what I've... -
by S70rm7r00p3rHi guys.
I am very new to this business and i have some questions. Maybe someone can help me further.
I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
by hexdyHello, I wanted to know if it is possible to modify a BIOS file to accept a legacy disk when it does not have the capability, I had this problem on a Optiplex 3060 that were donated to my job where we use non-uefi linux distros, we cannot use uefi since is a "big machine" with this systems beign the center of all of it, we can't change the distro now, maybe make some changes, but if I can modify the BIOS it would be awesome.
- Loading...
