Remove_SMM... UEFI.
  • Karol
    • May 2016
    • 90
    #701
    Re: Remove_SMM... UEFI.
    Originally posted by Sjenja
    Thank you for the patch, could you expand on a bit on the process on modding the bios ?
    Okay a bit of feedback here, this modded bios did do its magic , but now after I have flashed the old original bios back, it will not boot it just sits with black screen and no fan, no sound, should I clean the ME region or do something else before flashing the old bios back ?
    If the BIOS is original one, you don't need to clean ME Region.
    It's important after pach to start and enter in BIOS setup and load default settings (F9) then save. It is mandatory to do that in order to assert the configuration and ACPI tables.
    Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.
    • Sjenja
      • Jun 2016
      • 10
      • GoingDownTHeDrainCountry
      #702
      OK i figured out what was wrong, my soldering skills were bad. SO after the patch, do you mean to start on the original bios and load default settings or on the modded bios and enter the default settings? Just for my clarification. Thx
      • Karol
        • May 2016
        • 90
        #703
        With original!
        The patched one it will not showing you BIOS setup.
        • dirigjenti29
          • Apr 2018
          • 20
          • alb
          #704
          Originally posted by CraterM
          Comming soon for last generation!
          Next week I will test one method
          im waiting for your replay
          thanks
          • RMSisGod88
            • Jan 2020
            • Israel
            #705
            Can someone please patch my x260 bios?
            • Sjenja
              • Jun 2016
              • 10
              #706
              With original!
              Yep worked well. thx. I also figured out there i whent wrong in modding the bios, BTW in my early attempts I inserted the BootOption in the lenovosetupstartupdxe and this made it possible to get into the bios and would only activae the mod when trying to change the SV password, but I think I used the wrong version of LenovoTranslateService, becaulse it would not accept any keys. I may explore that also, what do you think?
              • CraterM
                • Mar 2018
                • 180
                • Moldova
                #707
                Try
                • Glytch
                  • May 2020
                  • 19
                  • UNITED KINGDOM
                  #708
                  Hi Everyone
                  Can someone please help me mod the Helix 20cg Bios so that i can unlock it?
                  • Sjenja
                    • Jun 2016
                    • 10
                    #709
                    its strange i have unlocked several machines now all same model, some will not load the patched bios makenig 2x5 beeps and screen remains black, what is going on ? on other machines works repect, all same model.
                    Update: to fix this problem I used one of the other machines pached bios that worked on the original machine. Worked like a charm. Still dunno on why some patched bios files dont work.
                    • Sjenja
                      • Jun 2016
                      • 10
                      #710
                      Anyone got a Lenovo P50 20EQ bios? Im experimenting with that now. L560 modded bios that works on multiple units, have tested on two machines same bios no pass unlock. Added to archives at : https://www.badcaps.net/forum/showthread.php?t=81573
                      • bachir2004
                        • Feb 2015
                        • 439
                        • maroc
                        #711
                        can someone please help patch this X260.
                        • Ghamidi
                          • Mar 2020
                          • 306
                          • France
                          #712
                          try this file and valid with any key
                          good luck
                          • bachir2004
                            • Feb 2015
                            • 439
                            • maroc
                            #713
                            good luck
                            many many thanks it worked.Any solution for ssd password?
                            • onelook
                              • May 2020
                              • 27
                              Lenovo ThinkPad Y1 Yoga 1st Gen.
                              Could someone please generate or provide patch file
                              Thanks so much
                              • Sjenja
                                • Jun 2016
                                • 10
                                #715
                                Thanks so much
                                Try this
                                • Ghamidi
                                  • Mar 2020
                                  • 306
                                  • France
                                  #716
                                  Sorry i not hava solution of SSD password
                                  • dimkka
                                    • May 2013
                                    • 16
                                    • moldova
                                    #717
                                    Hey. please help remove SVP t480s
                                    • stevie
                                      • Apr 2010
                                      • 30
                                      #718
                                      does anyone have JTAG pinouts for MEC1653 on a t480s
                                      i see JTAG port under the WLAN but i don't think that's usable
                                      • dimkka
                                        • May 2013
                                        • 16
                                        • moldova
                                        #719
                                        Originally posted by stevie
                                        does anyone have jtag pinouts for mec1653 on a t480s
                                        i see jtag port under the wlan but i don't think that's usable
                                        Jtag should be universal, check
                                        • b4rdock
                                          • Jun 2017
                                          • 106
                                          • usa
                                          #720
                                          what programmer u have ?
                                          • GuiTi
                                            Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
                                            by GuiTi
                                            Hey everyone!
                                            I need help with my Lenovo Chromebook 100e Gen 3.
                                            Here are the details:
                                            • Motherboard: LA-L131P
                                            • MFG Date: 2022/01/07
                                            • MTM: 82J80001BR
                                            • MO: MPNXB2103001
                                            • Factory ID: LI123
                                            I bought a new Winbond 25Q128FVSG chip.
                                            The chip currently on the board is the same model but with different ending letters.
                                            I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
                                            The Chromebook is Google account locked, and I’ve already tried everything.
                                            I understand that I need to replace or...
                                            10-14-2025, 08:41 AM
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
