Remove_SMM... UEFI.
    Re: Remove_SMM... UEFI.
    Can someone inject what is needed into my bios file? As I am not having much luck with it. You can download my dumped bios flash file using link below;
    https://www.mediafire.com/file/5n51f...flash.rar/file
    My first attempt to do it, after i flashed it back to machine all I get is a black screen and a number of beeps repeated before machine then shuts off again.
      There is a small switch on the motherboard, should be next to internal battery connector. Press it and hold it down while you are using patched bios.
      Had the same issue with X260 today, almost gave up but that switch just had to be pressed.
      Laptop might restart several times, that is normal.
        SO 4th Gen you need to replace 2 dxe drivers and for 5,6,7,8 gen you need to replace 3 dxe drivers?
        is this good or did i not understood?
          For 4 and 5 gen I replaced 3 files - LenovoTranslateService, BootOptions and SystemPpisNeededByDxe.
          For 6th gen I used LenovoTranslateService and BootOptions. Just in case replaced Fingerprint scanner driver aswell because it was mentioned in an earlier post. Have not tried just using 2 files yet.
            fingerprint scanner driver is this the same as SystemPpisNeededByDxe?
            and do you have the generator
              No, it is not the same. But forget about the fingerprint scanner driver. For 4th gen you need just those 3 files.
              I modified LenovoTranslateService file so there is no need for a generator. I don't have a generator.
                can you share this modified file?
                  Yes i would be great if your share lenovotranslateservice withou key thanks
                    see private mail
                      hmmm, i cant enter private mail,
                      can you patch this bios file
                        Originally posted by said7002 View Post
                        see private mail
                          Can you send me modified lenovotranslateservice please ? My email is ************@gmail.com thank you so much
                          Last edited by SMDFlea; 09-30-2019, 05:40 PM. Reason: Removed personal email address
                            Ok, I see the little switch down near the internal battery. The only thing I replaced in the bios was the TranslateService, I wasn't sure what else to replace (or where to find things such as BootOptions etc).
                            Anyone able to patch my BIOS file?
                              see private mail
                              Are you able to share with me also? Please?
                                I still get the 5 beeps and using the button didn't help. I'll look into it further when time permits.
                                  Search previous post in this topic. There was a package which had all 3 files.
                                    Yes, that's the one I tried. I replaced the 2 of the 3 items from within that to my bios but after powering on with that bios it gives 5 beeps a couple of times and machine powers off.
                                    I tried using the button internally and no change.
                                      hi
                                      said7002 please share lenovotranslateservice withou key thanks
                                        Whats your model, anyway?
                                          Lenovo T460
