Remove_SMM... UEFI.
  • purana
    • Sep 2019
    • 14
    Re: Remove_SMM... UEFI.
    Can someone inject what is needed into my bios file? As I am not having much luck with it. You can download my dumped bios flash file using link below;
    https://www.mediafire.com/file/5n51f...flash.rar/file
    My first attempt to do it, after i flashed it back to machine all I get is a black screen and a number of beeps repeated before machine then shuts off again.
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      #82
      There is a small switch on the motherboard, should be next to internal battery connector. Press it and hold it down while you are using patched bios.
      Had the same issue with X260 today, almost gave up but that switch just had to be pressed.
      Laptop might restart several times, that is normal.
      • kerel
        Banned
        • Sep 2019
        • 10
        • netherlands
        #83
        SO 4th Gen you need to replace 2 dxe drivers and for 5,6,7,8 gen you need to replace 3 dxe drivers?
        is this good or did i not understood?
        • RethoricalCheese
          • Mar 2013
          • 1519
          • Estonia
          #84
          For 4 and 5 gen I replaced 3 files - LenovoTranslateService, BootOptions and SystemPpisNeededByDxe.
          For 6th gen I used LenovoTranslateService and BootOptions. Just in case replaced Fingerprint scanner driver aswell because it was mentioned in an earlier post. Have not tried just using 2 files yet.
          • kerel
            Banned
            • Sep 2019
            • 10
            • netherlands
            #85
            fingerprint scanner driver is this the same as SystemPpisNeededByDxe?
            and do you have the generator
            • RethoricalCheese
              • Mar 2013
              • 1519
              • Estonia
              #86
              No, it is not the same. But forget about the fingerprint scanner driver. For 4th gen you need just those 3 files.
              I modified LenovoTranslateService file so there is no need for a generator. I don't have a generator.
              • kerel
                Banned
                • Sep 2019
                • 10
                • netherlands
                #87
                can you share this modified file?
                • kiknusko
                  kiknusko
                  • Jan 2019
                  • 26
                  • Slovensko
                  #88
                  Yes i would be great if your share lenovotranslateservice withou key thanks
                  • said7002
                    Banned
                    • Sep 2013
                    • 15
                    • maroc
                    #89
                    see private mail
                    • kerel
                      Banned
                      • Sep 2019
                      • 10
                      • netherlands
                      #90
                      hmmm, i cant enter private mail,
                      can you patch this bios file
                      • kiknusko
                        kiknusko
                        • Jan 2019
                        • 26
                        • Slovensko
                        #91
                        Originally posted by said7002
                        see private mail
                        • kiknusko
                          kiknusko
                          • Jan 2019
                          • 26
                          • Slovensko
                          #92
                          Can you send me modified lenovotranslateservice please ? My email is ************@gmail.com thank you so much
                          Last edited by SMDFlea; 09-30-2019, 05:40 PM. Reason: Removed personal email address
                          • purana
                            • Sep 2019
                            • 14
                            Ok, I see the little switch down near the internal battery. The only thing I replaced in the bios was the TranslateService, I wasn't sure what else to replace (or where to find things such as BootOptions etc).
                            Anyone able to patch my BIOS file?
                            • purana
                              • Sep 2019
                              • 14
                              see private mail
                              Are you able to share with me also? Please?
                              • purana
                                • Sep 2019
                                • 14
                                I still get the 5 beeps and using the button didn't help. I'll look into it further when time permits.
                                • RethoricalCheese
                                  • Mar 2013
                                  • 1519
                                  • Estonia
                                  #96
                                  Search previous post in this topic. There was a package which had all 3 files.
                                  • purana
                                    • Sep 2019
                                    • 14
                                    Yes, that's the one I tried. I replaced the 2 of the 3 items from within that to my bios but after powering on with that bios it gives 5 beeps a couple of times and machine powers off.
                                    I tried using the button internally and no change.
                                    • przemek_79
                                      • 28
                                      • Poland
                                      #98
                                      hi
                                      said7002 please share lenovotranslateservice withou key thanks
                                      • RethoricalCheese
                                        • Mar 2013
                                        • 1519
                                        • Estonia
                                        #99
                                        Whats your model, anyway?
                                        • purana
                                          • Sep 2019
                                          • 14
                                          Lenovo T460
                                          • nikola386
                                            Introducing Repair Assistant - A Free, Open Source Management System Built for Electronics Repair Shops
                                            by nikola386
                                            Hey BadCaps community, I built Repair Assistant, a management system for electronics repair shops. It covers tickets, customers, inventory, expenses, and reporting. What it does:
                                            • Repair ticket management — Track repairs with device details, status, priority, and notes
                                            • Expense & profit tracking — Track parts and labor per ticket with automatic profit calculations
                                            • Customer management — Database with contact info and repair history
                                            • Inventory tracking — Manage parts and components
                                            • Business analytics — Real-time stats, financial overview, profit margins, and trend charts
                                            • Professional
                                            Today, 02:52 PM
                                          • GuiTi
                                            Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
                                            by GuiTi
                                            Hey everyone!
                                            I need help with my Lenovo Chromebook 100e Gen 3.
                                            Here are the details:
                                            • Motherboard: LA-L131P
                                            • MFG Date: 2022/01/07
                                            • MTM: 82J80001BR
                                            • MO: MPNXB2103001
                                            • Factory ID: LI123
                                            I bought a new Winbond 25Q128FVSG chip.
                                            The chip currently on the board is the same model but with different ending letters.
                                            I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
                                            The Chromebook is Google account locked, and I’ve already tried everything.
                                            I understand that I need to replace or...
                                            10-14-2025, 08:41 AM
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
