Remove_SMM... UEFI.
    Re: Remove_SMM... UEFI.
    No, it should ask to press space twice. Maybe it hangs for some reason.
      Your patch is stuck, not continue on the next prosess
      When i check your file with ida, the file is not modified.
        I have modified by my self. And it working. Success to remove password x250. Just replace BE in hex editor into 00 according address on ida pro.
            Than share your patch bro.
              Could somebody send me patched bios file that has 6, 8, 9 or 10 digit Hardware ID?
                I can't find SystemPipsNeededbyDXE << where is this . Someone can copy GUID number for this SystemPipsNeededbyDXE ?? Im check file line by line but i cant find. Meybe this name is wrong ?
                  You don't need it anyway if you use uefitool.
                  And it does not excist on newer models anyway.
                    OK, i'm use UefiTool but my patch PE32 in (LenovoTranslateService and in BootOptions) works on many model L serries and T but in X1 Carbon 4 th (laptop start and beeps and not happend and turn off ) i use lock key and SSD ATA locked.
                    So looks like I need to change something else but what?
                      have you generator key ?
                        This is not answer about my question.
                        No i don't have generator. Someone can help with X1 Carbon 4th patch ?? how to make in this case ?
                          hiya bud thanks for the reply
                          the link doesnt work getting a 403 Forbidden error on it
                            got it needed to proxy it ill give it a try thanks
                              five beeps and power off?
                              If you have updated the bios recently read this
                              https://www.bios-mods.com/forum/Thre...onger-possible
                              https://www.insanelymac.com/forum/to...eps-on-lenovo/
                                5beeps pause 5beeps
                                  thanks biospwn got that working
                                  can confirm file works on lenovo 440s
                                    Can anyone help me modyfi my x1 3gen bios. When i try after enter key laptop stop response.
                                      Success, this file work
                                        This is for X1 5th Gen or 3rd Gen ?
                                          I was check dump it's for ThinkPad X1 Carbon 3rd.
                                          Someone help my with X1 Carbon 4 th :
