Hp probook 450 g4( da0x83mb6h0) rev:h bios dump
  • JS1982
    • Oct 2020
    • Nederland
    Re: Hp probook 450 g4( da0x83mb6h0) rev:h bios dump
    Originally posted by peste
    post the original laptop bios
    Here you are
    • peste
      • 12872
      • ROMANIA
      Originally posted by JS1982
      Here you are
      the posted bios is not ok..it must have 16MB ... remove the bios chip from the motherboard before reading or writing..make a copy of the bios check it with the HxD program and post it here ..
      • npl2
        • Nov 2020
        • Malta
        hi guys
        i've got this bios locked. Can someone help me unlock it pls
        thanks in advance
        • afzal1977
          • Sep 2020
          • pakistan
          thanks
          • canali
            • Oct 2014
            • 192
            • turkey
            thanks
            • Askic
              • Sep 2018
              • 187
              • BIH
              #26
              Hp 450 g4
              Hello I need a clean BIOS/SPI ROM for HP 450 G4, motherboard DA0X83MB6H0, rev H.
              Attached is actual BIOS dump with which I have a boot loop problem.
              Thank you!
              • peste
                • 12872
                • ROMANIA
                #27
                Re: Hp 450 g4
                Thank you!
                try..
                • Askic
                  • Sep 2018
                  • 187
                  • BIH
                  #28
                  Re: Hp 450 g4
                  Thank you very much for your effort. Unfortunately, this didn't solve my boot loop problem. Most probably, I have some kind of problem with the motherboard.
                  • sebulica
                    Beginner
                    • Mar 2014
                    • 50
                    #29
                    Hp 450 G4 rev D
                    I could not find anywhere bios for a HP450 G4 with intel graphics.
                    The board model is DAX63CMB6D1 Rev D.
                    Sistem reports a corrupted bios.I have tried recovering it via hdd,ssd and usb (WIN+B) but to no avail.If i remove the bios battery and fully reset it,the sistem starts 1 time and tells me that the RTC has been reset and allows me to press enter for restart.From there it enters the bios error code (2 blinks long 2 short,2 beeps long 2 short) and does not do anything unless i reset the RTC again.
                    Any solutions or a good bios dump?
                    I have attached the old bios
                      • 21029
                      Re: Hp 450 G4 rev D
                      Are you using a sop8 clip and a CH341A programmer to make the backup ?
                      • aboumohamed
                        • Dec 2018
                        • 258
                        • algeria
                        #31
                        Re: Hp 450 G4 rev D
                        TRY THIS DUMP MOTHERBOARD probook 470-G3-DAX63CMB6D1-REVD
                        password ISLAM
                          • 21029
                          Re: Hp 450 G4 rev D
                          password ISLAM
                          No good, the 470 G3 has BID N78 .The 450 G4 has BID P85 or P91
                          • sebulica
                            Beginner
                            • Mar 2014
                            • 50
                            #33
                            Re: Hp 450 G4 rev D
                            Yes.With v1.38 software.it's something russian but recognises the chip ok and programs many more than the old one.
                            you can get it here : https://www.upload-4ever.com/ddf9tgwm21vy
                            the setup is in russian but just press the right arrow until it finishes and you will find it in start menu installed
                            • sebulica
                              Beginner
                              • Mar 2014
                              • 50
                              #34
                              Re: Hp 450 G4 rev D
                              i prefer removing the bios from the board and programming it separately.i have enough experience to not damage the board or the chip.and when i resolder it i allways remove the battery to avoid accidental corruption
                                • 21029
                                Re: Hp 450 G4 rev D
                                I already know about alternative CH341A software, i usually recommend NeoProgrammer and ASProgrammer,but theres others too such as colibri and flashrom.
                                https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
                                https://www.badcaps.net/forum/showpo...6&postcount=10 AsProgrammer
                                Try NeoProgrammer. Check the backups with a hex editor such as HxD and make sure theyre the same, then post your new backup .
                                • sebulica
                                  Beginner
                                  • Mar 2014
                                  • 50
                                  #36
                                  Re: Hp 450 G4 rev D
                                  i have reatached the backup from the board.the first one posted was wrongly named.sorry
                                    • 21029
                                    Re: Hp 450 G4 rev D
                                    What is the full model number ,is it 450 G3 or G4
                                    • sebulica
                                      Beginner
                                      • Mar 2014
                                      • 50
                                      #38
                                      Re: Hp 450 G4 rev D
                                      ...well there is not 450 g4 with that model of mb...maybe i should have started with that...sorry
                                      it seems that this board is meant for HP ProBook 450 G3....anyone has a working bios?
                                        • 21029
                                        Re: Hp 450 G4 rev D
                                        Use the forum search,there`s plenty posted already,find one with clean ME firmware, you can check with MEAnalyzer. And it must be BID N78 ,you can find that with a hex editors text search function.
                                        The bios at post #3 is N78 but the ME is "initialised" (using MEAnalyzer)which means its not clean,find one with "configured" FW.
                                        • sebulica
                                          Beginner
                                          • Mar 2014
                                          • 50
                                          #40
                                          Re: Hp 450 G4 rev D
                                          I found a "factory bios" and i am posting this to help other in case they need it
                                          After you flash this bios it will be in "Factory mode".From there you must program the bios with apropriate information obtained usually from HP PartSurfer using the SN of the machine.
                                          FeatureByte,BuildID and SerialNumber are required in order for the machine to function properly.The SKU Number (Storage Keep Unit) is only relevant for a company to track the device or sometimes for the seller to track the warranty,but you can set the PN of the unit there.The Board CT Number (Commodity Tracking) is required for HP to identify and associate the board with the SN of the equipment in order to issue the warranty;this way they can tell if the board was swapped or tampered with.You can find the CT number on the board as a sticker or sometimes as a QR code.Product Family and Product Name are required for large companies to deploy software based on that info.
                                          To get past the factory mode you can use the HP service tool wich (DMI) ,or you just restart the unit until the counter reaches 0.
                                          The tool can be used on other hp equipments.
                                          Part Surfer : https://partsurfer.hp.com/Search.aspx
                                          Hope this will help others
                                          Cheers!
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • studdy05
                                            Bricked HP Probook 450 G7 Bios questions
                                            by studdy05
                                            Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                            Ive got...
                                            07-08-2025, 09:24 PM
                                          • haitham sharabati
                                            by haitham sharabati
                                            Hello engineers 😀,
                                            🔧 Device Info:
                                            - Model: HP 15-da2007ne
                                            - Product Number: 8XF55EA#ABV
                                            - Serial Number: CND0338P0D
                                            - CPU: Intel Celeron N4000
                                            💀 Problem:😅
                                            08-07-2025, 04:54 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
