Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
Hp probook 450 g4( da0x83mb6h0) rev:h bios dump
    Posted Photos 6 Photos
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • kinojk2
    ASUS Prime Z790-P (NON-WIFI) Bios dump and questions
    by kinojk2
    Hi, Thanks for all you do here.
    I have attached my 16MB dump.
    EDIT2: All hardware working fine, I think I just need to update my linux booatloader and all gucci
    EDIT:
    I can get into bios now! I reflashed as instructed elsewhere. With a minimal POST (just 1 stick of ram , GPU, CPU, no drives) I have loaded into BIOS. I am about to reinstall my other hardware components now.
    The clips are such a pain to use, soldering would be a great skill to have.
    Thanks for the advice in other threads!
    To answer my own question, I didn't...
    03-24-2026, 05:55 AM
  • studdy05
    Bricked HP Probook 450 G7 Bios questions
    by studdy05
    Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
    Ive got...
    07-08-2025, 09:24 PM
  • dragic98
    BIOS Dump for Lenovo Yoga Slim 7 15ILL9 (83HM) LNVNB161216
    by dragic98
    Model: Lenovo Yoga Slim 7 15ILL9
    Machine Type Model: 83HM
    Motherboard ID: LNVNB161216
    TLDR: I would like to have the clean BIOS dump file for my laptop model.
    Issue: First, my speaker wasn't working/showing up, so I downloaded the recommended BIOS update (from Jan 4, 2026) on Lenovo Support for my laptop. This didn't fix the speaker issue after restarting, so then I shut it down and pressed the power button for 60 seconds to perform a reset. I'm guessing I somehow messed up the BIOS because now the laptop won't turn on even after trying the NOVO button on...
    03-27-2026, 11:45 PM
