Lenovo T450 BIOS password Dump
  • snar
    • Feb 2018
    • 74
    • philippines
    #81
    Originally posted by Markus1741
    Hello try this patched file ....
    thank you very much sir. i'l update after i flash this bios.
    • snar
      • Feb 2018
      • 74
      • philippines
      #82
      sir thank you. the bios is ok. but when i press F1 to enter bios. its stays blank it has backlight but no image. i cannot continue to bios. can you clean the bios sir. thanks in advance.
      • jonassonic
        • Mar 2024
        • 9
        • brasil
        #83
        please, generation file patch, the file _patched is not gen
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1355
          • France
          #84
          You are requesting help
          If you do not abide by the following rules, your post will be deleted.
          You MUST NOT:
          • Hijack threads unrelated to your request
          • Post a request in multiple threads
          • Post a request multiple times
          • Post in foreign (non-English) languages
          • Share private contact information
          • Offer payment of any kind whatsoever
          • Bump your thread or post more than once every 48 hours. If you do so
            you will receive an infraction
          • Post "clean me", "clear bios", "clean bios", "fix bios", "bios need", "clear me" or other such terms
          You MUST:
          • Read BIOS guides, methods, resources and tools
          • Try the method at BIOS guides, methods, resources and tools before requesting help
          • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
          • Use search function in case someone already answered your request
          • Post under a related thread if it exists
          • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
          • Name your thread with make, full model numbers and request
          • Provide a BIOS/EC dump if possible
          • Attach files directly to your post instead of linking to external websites
          • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
          • mazi54
            • Sep 2023
            • 28
            • poland
            #85
            Try
            • DAHOUD
              • Sep 2023
              • 35
              • Tanzania
              #86
              Please help me to unlock bios password
              lenovo T450
              Motherboard number NM-A251
              Seriel number L1HF58L070P
            • DAHOUD
              • Sep 2023
              • 35
              • Tanzania
              #87
              Previously i did through autopatcher but after changing laptop i used before because i have been stolen all my tools now i got difficulties in installing python it looks window lack some features, in a process of seaching proper window image i got this work please i beg you to help me just for now
              • tkn666
                • Apr 2021
                • 3
                #88
                Hi there,
                need password remove from bios can any one help
              • tkn666
                • Apr 2021
                • 3
                #89
                Lenovo T450 TB0050B
                S/N PC-05VM4K
                Motherboard: AIVLO NM-A251 REV.1.0
              • smali
                • Sep 2014
                • 287
                • Pakistan
                #90
                Originally posted by shabi
                Re: lenovo t450 bios password
                STEP 1: Flash and replace current BIOS with the generated patch file
                STEP 2: Boot the machine
                STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                STEP 4: Enter any character when asked for Supervisor Password
                STEP 5: Press enter when it shows Hardware ID
                STEP 6: Press space bar 2x when asked
                STEP 7: Turn off machine
                STEP 8: Restore original BIOS
                STEP 9: Reset BIOS settings to factory default
                Hi... Will this patched bios work on other t450 or only it is for specific t450?
                  SMDFlea commented
                  Editing a comment
                  try it and see
              • smali
                • Sep 2014
                • 287
                • Pakistan
                #91
                Originally posted by imranromi
                Re: Remove_SMM... UEFI.
                Not work many hwid cannot generate
                Hi sir, how are you? Can you remove bios password from t450 Lenovo? T450 with p/n SL10H09572
                  • 21962
                  Havn`t you tried the Autopatcher https://www.badcaps.net/forum/troubl...86#post3249786
                  • danito
                    • Jun 2016
                    • 1098
                    • Romania
                    #93
                    STEP 9: Reset BIOS settings to factory default​
                    • Octave
                      • Aug 2024
                      • 9
                      • France
                      #94
                      Hello guys
                      I have tried all I can but I really need your help as I can't boot my T450 NM-A251 anymore
                      Removed supervisor password successfully and I could access bios, but could only boot my system partially (machine stopped in win 10 boot process) and restarted.
                      Tried to reinstall the computer from usb media (W10pro). I tried both legacy and UEFI boot options, even changed ram and ssd, no success. Black screen at loading the installation files (led activity on the usb key) then i got stuck on a stripped orange screen. i tested the screen and all hardware, no issue, all passed correctly.
                      I tried the Clean ME method on the patched bin file and I got a 2x 5 beeps loop but could not enter the bios then, just got error message saying: bad CRC of security settings in EFI variable , press F1 to enter setup , but F1 leads nowhere but a black screen.
                      I rolled back to original 1. file, accessed bios without password and I restted to defaults factory setting: the CRC message disappeared but i still could never reisntall the computer (same striped orange screen)
                      I checked the bin file with UEFItool and it shows last area in red, but I don't know what to do.
                      It seems my bios I bricked since the beginning and the password removal does not help. I put the bin here (no password).
                      Could anyone check and maybe fix this?
                      Thank's a million for your help
                      UEFI Bios version JBET54WW (1.19) 2015-11-06
                      Embedded controller JBHT15WW (1.02)
                      ME Firmware version 10.0.30.1072
                      Machine Type 20BV0006US
                      Machine S/N PC07PN42
                      Motherboard S/N L1HF63G02T9
                      The bios is Winbond W25Q128FV, I used the CH341a module to extract, verify and patch with autopatch method.
                      • Octave
                        • Aug 2024
                        • 9
                        • France
                        #95
                        Originally posted by Octave
                        Hello guys
                        After a few more days of searching, sanity-saving breaks included, and a whole lot of “what the heck is happening,” the issue just... vanished.
                        Yesss, really like, poof, gone. I can't explain it.
                        Maybe it was because the battery had been disconnected for ages, or maybe—just maybe—the blue moon teamed up with my trusty chunk of tourmaline to work some energetic protection magic?!
                        Long story short, the motherboard suddenly sprang back to life, and I could finally boot the OS normally.
                        No rhyme, no reason—just pure, unexplainable tech voodoo. I'm half-convinced the tourmaline chased away whatever tech gremlins were lurking.
                        But hey, I'm not questioning it!
                        Whether it was the universe, some mischievous spirits, or a crystal-powered intervention, I'll take the win. => let's just keep the faith )))
                        • asep nurjaman
                          • Jan 2024
                          • Indonesia
                          #96
                          Sir, can I ask for help on the Lenovo T450 laptop lock bios, asking for a patched file
                          • danito
                            • Jun 2016
                            • 1098
                            • Romania
                            #97
                            read...https://www.badcaps.net/forum/troubl...before-posting
                            post the full name and model, motherboard model S/N, etc...
                            • bursauzman
                              • Nov 2018
                              • 42
                              • türkiye
                              #98
                              Lenovo T450
                              NM-A251
                              SN: PC-0E5XEA
                              TYPE: 20BU
                              please i need patch file for bios password
                              problem solved. Lenovo Autopacher
                              I thank everyone​
                              • medinfo
                                We can modify the "SecureBoot" state on Lenovo laptop from bios bin dump ? if bios password password on ?
                                by medinfo
                                03-07-2024, 07:28 AM
                              • Buzzfuzz2k
                                Bios password removal on a Unowhy dump
                                by Buzzfuzz2k
                                Hi Everyone,
                                I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                the Computer is a Unowhy small pc
                                N° UYM6524702229
                                After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                My first attempt was to get the bios dump from windows...
                                11-13-2023, 07:37 AM
                              • baaligoga
                                Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
                                by baaligoga
                                Good day, everyone!
                                I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
                                I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
                                05-20-2023, 09:48 AM
                              • dell_bios
                                Need unlocked BIOS dump for W25Q64FV (Admin Password removal)
                                by dell_bios
                                I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
                                The board has three SPI flash chips:
                                - W25Q64FV (main BIOS)
                                - W25Q32FV (EC/TPM)
                                - W25X10CL (configuration)
                                I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
                                The dump contains protection that needs to be removed.
                                If anyone has a clean or unlocked BIOS dump for W25Q64FV, I’d really appreciate it!
                                I’m also happy to share my dump for comparison if needed.
                                Laptop model: [please specify, e.g....
                                10-16-2025, 04:28 PM
                              • AHmad_Salal
                                Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                by AHmad_Salal
                                Hello all,
                                I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                11-28-2023, 05:28 AM
