Lenovo T450 BIOS password Dump
please, generation file patch, the file _patched is not genAttached FilesComment
You are requesting help
If you do not abide by the following rules, your post will be deleted.
You MUST NOT:- Hijack threads unrelated to your request
- Post a request in multiple threads
- Post a request multiple times
- Post in foreign (non-English) languages
- Share private contact information
- Offer payment of any kind whatsoever
- Bump your thread or post more than once every 48 hours. If you do so
you will receive an infraction - Post "clean me", "clear bios", "clean bios", "fix bios", "bios need", "clear me" or other such terms
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
- Name your thread with make, full model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
Try
Please help me to unlock bios password
lenovo T450
Motherboard number NM-A251
Seriel number L1HF58L070PAttached FilesComment
Read the rules and guides, try the lenovo Autopatcher https://www.badcaps.net/forum/troubl...96#post3238896
Previously i did through autopatcher but after changing laptop i used before because i have been stolen all my tools now i got difficulties in installing python it looks window lack some features, in a process of seaching proper window image i got this work please i beg you to help me just for nowComment
Hi there,
need password remove from bios can any one help
ThanksAttached FilesComment
read...https://www.badcaps.net/forum/troubl...before-posting
post the full name and model, motherboard model S/N, etc...
Hi... Will this patched bios work on other t450 or only it is for specific t450?Re: lenovo t450 bios password
STEP 1: Flash and replace current BIOS with the generated patch file
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter any character when asked for Supervisor Password
STEP 5: Press enter when it shows Hardware ID
STEP 6: Press space bar 2x when asked
STEP 7: Turn off machine
STEP 8: Restore original BIOS
STEP 9: Reset BIOS settings to factory defaultComment
Hi sir, how are you? Can you remove bios password from t450 Lenovo? T450 with p/n SL10H09572Attached FilesLast edited by smali; 07-23-2024, 06:58 AM.Comment
STEP 9: Reset BIOS settings to factory defaultAttached FilesComment
Hello guys
I have tried all I can but I really need your help as I can't boot my T450 NM-A251 anymore
Removed supervisor password successfully and I could access bios, but could only boot my system partially (machine stopped in win 10 boot process) and restarted.
Tried to reinstall the computer from usb media (W10pro). I tried both legacy and UEFI boot options, even changed ram and ssd, no success. Black screen at loading the installation files (led activity on the usb key) then i got stuck on a stripped orange screen. i tested the screen and all hardware, no issue, all passed correctly.
I tried the Clean ME method on the patched bin file and I got a 2x 5 beeps loop but could not enter the bios then, just got error message saying: bad CRC of security settings in EFI variable , press F1 to enter setup , but F1 leads nowhere but a black screen.
I rolled back to original 1. file, accessed bios without password and I restted to defaults factory setting: the CRC message disappeared but i still could never reisntall the computer (same striped orange screen)
I checked the bin file with UEFItool and it shows last area in red, but I don't know what to do.
It seems my bios I bricked since the beginning and the password removal does not help. I put the bin here (no password).
Could anyone check and maybe fix this?
Thank's a million for your help
UEFI Bios version JBET54WW (1.19) 2015-11-06
Embedded controller JBHT15WW (1.02)
ME Firmware version 10.0.30.1072
Machine Type 20BV0006US
Machine S/N PC07PN42
Motherboard S/N L1HF63G02T9
The bios is Winbond W25Q128FV, I used the CH341a module to extract, verify and patch with autopatch method.
After a few more days of searching, sanity-saving breaks included, and a whole lot of “what the heck is happening,” the issue just... vanished.Hello guys
Yesss, really like, poof, gone. I can't explain it.
Maybe it was because the battery had been disconnected for ages, or maybe—just maybe—the blue moon teamed up with my trusty chunk of tourmaline to work some energetic protection magic?!
Long story short, the motherboard suddenly sprang back to life, and I could finally boot the OS normally.
No rhyme, no reason—just pure, unexplainable tech voodoo. I'm half-convinced the tourmaline chased away whatever tech gremlins were lurking.
But hey, I'm not questioning it!
Whether it was the universe, some mischievous spirits, or a crystal-powered intervention, I'll take the win. => let's just keep the faith
Lenovo T450
NM-A251
SN: PC-0E5XEA
TYPE: 20BU
please i need patch file for bios password
problem solved. Lenovo Autopacher
I thank everyoneAttached FilesComment
by medinfoWe can modify the "SecureBoot" state on Lenovo laptop from bios bin dump ? if bios password password on ?
by Buzzfuzz2kHi Everyone,
I'm facing a problem with a locked bios with a password and i can't find how to remove it...
The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
the Computer is a Unowhy small pc
N° UYM6524702229
After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
My first attempt was to get the bios dump from windows...-
by baaligogaGood day, everyone!
I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...-
Channel: BIOS Requests ONLY!
by dell_biosHi everyone,
I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
The board has three SPI flash chips:
- W25Q64FV (main BIOS)
- W25Q32FV (EC/TPM)
- W25X10CL (configuration)
I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
The dump contains protection that needs to be removed.
If anyone has a clean or unlocked BIOS dump for W25Q64FV, I’d really appreciate it!
I’m also happy to share my dump for comparison if needed.
Laptop model: [please specify, e.g....-
by AHmad_SalalHello all,
I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....-
- Loading...
