Asus X541UVK Bios
Re: Asus X541UVK Bios
Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Hi All, please can i get assistance with Asus X541UVK rev2.0. Windows updated the firmware with x541UAK... Now the laptop powers on but doesnt charge, Charging LED solid white. Also, not sure on the procedure to Flash the rom, i have the stock bios UVK.308. Anu guide on how to flash it. Looked at AFUDOS, finding the commands complicated.
Any help would be appreciated, thanksComment
Any help would be appreciated, thanks----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
then you have to read bios chipset with programmer and post the dump here along with serial number and board ID's, including QR code.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Hi All, so I found another post with the same issue where just the battery won't charge. However no response. Can this be done for me please.
Could someone modify F541UA bios so it will be read as F541UAK?
Version 307 (F541UA): https://dlcdnets.asus.com/pub/ASUS/nb/X5...AAS307.zip
Version 311 (F541UAK): https://dlcdnets.asus.com/pub/ASUS/nb/X5...KAS311.zipComment
Also post a picture of the white barcode sticker next to the soldered ram ,if there is one.
.Comment
Hi SMDFlea, The serial number is H5N0CX103759209... Unfortunately no sticker.
So the actual bios i need is f541UA...the latest on asus website is .307. AFUWINGUI complains about Size of rom file does not match the size of system rom. And thats where im stuck.Comment
The file from the ASUS homepage is an incomplete file, you need the original bios file to create a complete bios file.↵
​https://www.badcaps.net/donateComment
Attached FilesComment
Go to the setup tab on AFUWIN tick main bios image ,untick program all blocks.
.Last edited by SMDFlea; 10-30-2023, 06:17 AM.Comment
So, look at the image attached: open UEFITool, load X541UAAS.307, extract capsule, save it as .rom file, download AMIBIOS_and_Aptio_AMI_Firmware_Update_Utility, copy extracted file in AFUWin/64 folder, launch AFUWINx64.exe , load saved file, check "Main Bios image", uncheck "program all blocks" then click on "Flash" tab.Last edited by volinakis; 10-31-2023, 03:46 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
when you open AFUWIN what size of bios is displayed? take a picture and post it.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
I had 3 people contact me in a week because Windows suddenly didn't boot:
As you can see, all 3 are ASUS computers, but I believe the common factor is the BIOS being American Megatrends (AMIBIOS/APTIO).
The first two recovered just fine after a restart, but the third one didn't and was brought to me. The model is F541UV (X541UV).
Setup allows to add a boot option manually and the operating system boots just fine from both bootx64.efi and bootmgr.efi. However, there is no way whatsoever to save the option(s): upon a reboot the machine goes straight...-
- Loading...
