HP Probook 4540s - BIOS
  • hoaca388
    replied
    Re: HP Probook 4540s - BIOS
    Originally posted by kraze
    I posted above, as requested (sorry for bump).
    Try
  • kraze
    replied
  • kraze
    replied
    Attached.
  • hoaca388
    replied
    Post the file before you correct the information to FF
  • kraze
    replied
    Hi, my first (second) post here.
    I have two similar HP ProBook 4540s-es with Radeon HD graphics on board, one had a dead bios chip. I managed to revive it by dumping an image from the working one with UsbAsp, flashing it to the clean flash chip, and replacing it on the dead one.
    Now the problem that I cannot resolve, is how to replace UUID, SKU and CSN with the proper ones.
    I have replaced the relevant numbers with those proper to the case (UUID left intact), flashed the image, soldered the chip back in place, but the laptop would just blink the power button, as if BIOS is wrong.
    I replaced the old ones with FFFFs and the laptop does boot.
    Also,where can I find an UUID for it, I cannot seem to find it anywhere on the case.
    Dump with cleaned password and serials attached.
    Before you ask me - yes, I have tried NbDmiFit in various uses, but I cannot get MPM unlocked.
    I.e. uefimpmunlock.efi method with various versions gives me some MEFirmware error.
    FSMC.bin -> SMC.bin method just lights up the CapsLock lighgt and does not unlock MPM.
    So, the most sure method would be to replace the serials directly in the binary or , probably, have the MPM bit set to 1 therein, but I could not find any MPM-related stuff in the dump except for the counter and as specified above, the direct replacement of serial to something different to FFFF makes the system unbootable.
    Please provide an advice, method or modify my firmware to make it MPM unlocked.
    Thank you.
  • peste
    replied
    Originally posted by bokeboke
    Thanks PESTE It worked.. one more thing if I try to use amd graphic does this dump still works?
    THANK YOU GuYS
    I don't know .. try ...
  • bokeboke
    replied
    THANK YOU GuYS
  • peste
    replied
    Hi friends i have this original proobook dump bios
    I tryed the uma version bios after removed the big coil on motherboard but still full fan spin..
    try...
  • bokeboke
    replied
  • mc12
    replied
    thanks
  • soufari
    replied
    Re: In dire need of bios bin file for Probook 4540s
    thanks
  • soufari
    replied
    Re: HP Probook 4540s Charging LED goes Amber color and goes off
    Originally posted by String2016
    try to flash the bios first try with this dump
    thanks
    replied
    Originally posted by Okoroji victor
    Please send me the file
    Read through the whole of the thread you`ll find a bios.
  • Okoroji victor
    replied
    Originally posted by dycc
    need probook 4540s bios dump .
    Originally posted by dj_ricoh
    i already did 3 notebooks 4540s that file its awesome it save my ass
  • see1001
    replied
    Re: HP Probook 4540s working BIOS
    Originally posted by subroto
    Happy new year friends....
    This is working BIOS for HP Probook 4540s UMA version.
    uma version work.thanks.
  • Oliver111
    replied
    Thanks mate. Working fine for 4540s i5-3210m UMA.
  • jmgcasilva@gmail.com
    replied
    Re: hp probook 4540s
    Thank you
  • max7
    replied
    tanks
  • huss584
    replied
    Re: ProBook 4540s BIOS
    Thank You Man
  • hojnikb
    replied
    Originally posted by peste
    enter the DMI information ...
    https://www.youtube.com/watch?v=9T57ktw8n3Y
    Thank you, i'll try this!
  • to5it0
    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
    by to5it0
    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
    I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
    This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
    I have opened the laptop and identified the main BIOS chip...
    10-24-2025, 01:35 AM
  • studdy05
    Bricked HP Probook 450 G7 Bios questions
    by studdy05
    Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
    Ive got...
    07-08-2025, 09:24 PM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • maanee11
    Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
    by maanee11
    Hello Everyone,
    I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
    It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
    In the website, you can only see specs etc.
    I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
    Today, 04:08 AM
  • m1ch43lzm
    Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
    by m1ch43lzm
    Hi everyone
    I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
    Programmer models: XGecu TL866II Plus / T48 / T56 / T76
    Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
    There's also an extra OTP Secu.R...
    09-06-2025, 05:47 PM
