HP Probook 4540s - BIOS
  • ugur010
    • Nov 2023
    • mersin
    #141
    Re: HP Probook 4540s - BIOS
    hello, my 4540s fan is running fast, is it necessary to disassemble the bios to flash these bios, is there anyone who can explain how to install it, is there anyone who can separate the bios from the motherboard and flash it in a different way, help please
    • timematcher
      • Oct 2023
      • 12
      • Pakistan
      #142
      Originally posted by peste
      try this..
      Hi @peste. Thanks for your reply and the bin image you attached. I appreciate it very much indeed.
      I flashed your outimage1.bin on the 8MB chip (which is currently soldered to the board) after a full erase and I got a "blinking charger" LED. I did not get any display. CPU did not seem to POST.
      Gentle Reminder : I am using a 4540s's BIOS on HP Probook 4530s to get IvyBridge Support with i7-3840QM processor on 4530s chipset (HM65) - which works fine but with some issues . For context see OLD post here with screenshots:
      https://www.badcaps.net/forum/showpo...&postcount=139
      I noticed the following with outimage1.bin which you provided:
      1. The bin image is 4096KB for the original MX25L3206E 4MB chip while the chip I am using is an 8MB chip (W25Q64FVSIQ)
      2. The bin image has an ME of 7.1 while 8.1 ME is required for IvyBridge support (i think)
      3. The bin image does not seem to have any Ivybridge GOP driver ( I used UEFITool to check and I am not an expert so please excuse my ignorance in this regard).
      4. The bin image seems to have microcodes only for 000206Ax while i think, for 000306AXh is required for IvyBridge i7-3840QM
      Here by X i mean numerics for revisions
      Quick questions:
      1. Could you share technical details regarding what things did you change in this outimage1.bin you attached?
      2. Should I put the 4MB chip back and flash this image?
      3. Maybe it's a good idea to modify the 4540s image I attached in my message ( i am attaching it again for reference)
      Please note that Probook4530s had a 4MB chip originally which I have replaced and put in an 8MB chip to allow flashing of 4540s BIOS and that the attached "[4540s]8.1.0.1248_1.5MB_PRD_RGN_Audio-Disabled_WLAN_LAN_GPUs_SSD_OpticDrv_16GB_RAM_FAN_DateTime_.zip 8MB image" works on 4530s with an 8MB chip but with problems mentioned in previous posts.
      Side by Side Comparison (left[blinking LED] vs right (working but with issues))
      ME version 7.1 vs ME version 8.1 - 8.1 is required (i believe)
      000306AXh microcode is required for IvyBridge i7-3840QM
      IvyGOP is required which is present in 4540s BIOS but missing in outimage1.bin
      @peste
      The only issues with you (originally submitted) BIOS i.e. https://www.badcaps.net/forum/attach...9&d=1699204636 are the following issues:
      1. Keyboard is very slow
      2. Touchpad is very slow
      3. Audio must be disabled in BIOS only then windows 10 or windows 11 installs/boots.
      4. Win11/Win10 writes something to [4540s]8.1.0.1248_1.5MB_PRD_RGN_Audio-Disabled_WLAN_LAN_GPUs_SSD_OpticDrv_16GB_RAM_FAN_DateTime_.zip bios in the chip after Windows Updates and a result, laptop stops posting
      Can we fix these issues somehow? I am happy to use the 8MB BIOS ([4540s]8.1.0.1248_1.5MB_PRD_RGN_Audio-Disabled_WLAN_LAN_GPUs_SSD_OpticDrv_16GB_RAM_FAN_DateTime_.zip ) on an 8MB chip and not the 4MB one because I believe it lacks IvyBridge and ME support. Only if we could fix the above issues!
      Laptop : HP Probook 4530s (HM65 Chipset)
      CPU: i7-3840sQM
      Working BIOS (with some problems) : [4540s]8.1.0.1248_1.5MB_PRD_RGN_Audio-Disabled_WLAN_LAN_GPUs_SSD_OpticDrv_16GB_RAM_FAN_DateTime_.zip
      Working ME : 8.1.0.1248
      Chip Used : W25Q64FVSIG
      Appreciate you taking the time to read my post and your response.
      • rex98
        • Feb 2023
        • 1278
        • Mandaue CEBU, Philippines
        #143
        try this...
        • timematcher
          • Oct 2023
          • 12
          • Pakistan
          #144
          Originally posted by rex98
          try this...
          Hi Thanks for sharing the 4540s BIOS image.
          Maybe you didn't intend it for me as but I tried it anyway
          Your BIOS image POSTs, BIOS is loaded but when making any change such as BOOT type, and then using F10 to save settings, it does not seem to save settings and as a result it is not possible to load UEFI boot from the Disk.
          So far, only @peste's 4540s' BIOS works on 4530s, saves settings, loads OS but has some other issues e.g.
          1. Audio must be disabled in BIOS (to prevent Driver PNP Watchdog BSOD)
          2. only 2 USB (R.H.S) ports work, NEC/Renesas USB 3.1 do not work,
          3. Restart/Shutdown operations from OS don't work, hardware does not restart/power off, continues to shutdown/restart for a very long time then results in BSOD and then system resets (normal after a BSOD).
          4. Underlying Keyboard & touchpad (EFI?)driver is extremely slow like a tortoise. It's extremely slow. You have to hard-press keys and then wait for the key to work after 3 seconds then delay 3 seconds then press another key and so on...
          The behavior of keyboard/touchpad/mouse is the same in BIOS as well as after the OS is loaded. so a USB keyboard and USB mouse has to be attached to make things work. This occupies the only two working USB ports
          • timematcher
            • Oct 2023
            • 12
            • Pakistan
            #145
            So I have not given up and during the last few weeks, I was able to break BIOS signature (dual) verification and now modification to any DXE volume does not cause any blinking LEDs.
            now the only things left to do are the following:
            3. Restart/Shutdown operations from OS don't work, hardware does not restart/power off, continues to shutdown/restart for a very long time then results in BSOD and then the system resets (normal after a BSOD).
            4. The underlying Keyboard & touchpad (EFI?)driver is extremely slow like a tortoise. It's extremely slow. You have to hard-press keys and then wait for the key to work after 3 seconds then delay 3 seconds then press another key and so on...
            I need help identifying the Audio DXE Driver/module, Keyboard, and power monitor modules in 4530s and 4540s modules.
            For the keyboard, I replaced (from the 4530s BIOS into the modified 4540s) KBC flash, EfiLowLevelKeyboard, and all Keyboard-related DXEs but they did not seem to have any effect... BIOS still works with the aforementioned issues.
            So this leads me to think there is some other PEI module that is loaded during POST that eventually becomes responsible for keyboard or touch handling.
            or maybe there is some kind of clock speed frequency thingy that is causing the sluggish behavior of the native keyboard and touchpad.
            Any help or guidance will be appreciated.
            • ugur010
              • Nov 2023
              • mersin
              #146
              I have the same problem, why does no one give me information on how to install it?
              • TIXOU14
                • Aug 2020
                • 15
                • TIARET
                #147
                try this...
                tested work 100%
                • timematcher
                  • Oct 2023
                  • 12
                  • Pakistan
                  #148
                  You need a SOIC8 clip and a programmer such as CH341A programmer (and some knowledge/experience) to flash the BIOS.
                  In the case of 4540s/4530s, the BIOS can be flashed without removing the chip from the board. But you must remove/unplug the battery from the laptop and obviously remove the power cord from the laptop too (otherwise you will almost definitely burn your programmer).
                  Lastly, if the fan is spinning really fast and there is no display on your 4540s then most likely it is a CPU problem or a RAM problem and less likely a BIOS issue. but you could try using the appropriate/correct BIOS for your laptop/chip.
                  You should also share the Charger port LED's symptoms and behaviors i.e. color changing, blinking a certain number of times, etc. The Charger port LED's blinking behavior and the number of times it blinks have specific meanings which are all documented on the HP website in the support documents. A quick Google search could lead you to the exact page for your specific model of the laptop.
                  if you need specific help, I would suggest that you post exact and specific details of the issue along with the behavior of the Display, Fan, and charger port LED's behavior (whether it's normal, indicating charging? or just blinking or changing colors?). if you have recently changed/replaced the CPU, please share which CPU was previously present and which new one you installed now. The more specific your details are, the more likely is the chance that you will get a helpful response.
                  • douglas.01
                    • May 2024
                    • Brasil
                    #149
                    thanks brows
                    • Jnmbc20
                      • Jan 2020
                      • 13
                      • Kenya
                      #150
                      Hello everyone, I have a HP probook 4540s that i flashed with BIOS downloaded from this site. What tools can i use to change the serial number to match the laptop chassis?
                    • mv707
                      • Jun 2023
                      • 21
                      • Azerbaijan
                      #151
                      Originally posted by String2016
                      Re: HP Probook 4540s Charging LED goes Amber color and goes off
                      try to flash the bios first try with this dump
                      thanks
                      • (0)_(0)
                        • Nov 2020
                        • LK
                        #152
                        Hello All, Could someone help me with fixing this BIOS dump? Keyboard is really slow. It has touchpad issues as well. It's working fine with an external keyboard.
                        Model: ProBook 4540s (Intel i5-3210M. UMA)
                        Board Number: E89382 94V-0 MV-6 HannStar
                        Edit: I've tried a bunch of files posted in this thread and none of them worked for me.
                      • (0)_(0)
                        • Nov 2020
                        • LK
                        #153
                        Serial: 2CE2361D1Z
                        Sorry, Didn't think the serial was needed, and I can't edit the original post.
                        • Ismail Siraje Ittembe
                          Kampala Member
                          • Jan 2024
                          • 25
                          • Uganda
                          #154
                          HP Probook 4540s
                          Serial JPA316QMNJ
                          Product B4N94AV
                          blinks power button​
                          • peste
                            • 12792
                            • ROMANIA
                            #155
                            Originally posted by Ismail Siraje Ittembe
                            HP Probook 4540s
                            Serial JPA316QMNJ
                            Product B4N94AV
                            try..
                            • volkswagenvan
                              Volks
                              • Mar 2009
                              • 35
                              Winter Project of my old HP Probook 4540s.
                              Symptoms...
                              The fan was spinning really fast after a few moments of pressing the power button and there was no display.
                              Caps Lock Light blinking continuously and I could not turn it off without removing the battery and power supply.
                              Just for fun, I Fired up my programmer today and read the bios and saved it.
                              Then erased and Programmed the file posted of "Orig=Rom+Outimage.bin" Not thinking
                              That this could fix anything but...... It has Good signs of life and the pc is having the fit about
                              no serial,model, etc!
                              I`m Excited about my New / Old computer!
                              Does anybody smarter than me have the abillity to port the old information over to a clean Bin?
                              Thank`s for any support ahead of time!
                                SMDFlea commented
                                Editing a comment
                                post the laptop serial number.
                            • volkswagenvan
                              Volks
                              • Mar 2009
                              • 35
                              Serial: 2CE3321HNK
                              • volkswagenvan
                                Volks
                                • Mar 2009
                                • 35
                                I Have tried to change Information to correct the product information not valid myself.
                                My hats off to those who can do this without pulling all their hair out!
                                • peste
                                  • 12792
                                  • ROMANIA
                                  #159
                                  Originally posted by volkswagenvan
                                  Serial: 2CE3321HNK
                                  try..
                                  • volkswagenvan
                                    Volks
                                    • Mar 2009
                                    • 35
                                    That Did not work at all. Brings back all the old problems Fast!
                                    No Boot, Flashing caps lights, Fast Fan.
                                    Thank`s for trying anyways! Anymore Ideas?
                                    • studdy05
                                      Bricked HP Probook 450 G7 Bios questions
                                      by studdy05
                                      Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                      Ive got...
                                      07-08-2025, 09:24 PM
                                    • Citymin
                                      by Citymin
                                      S/N : 5RNK9FFT70...
                                      Today, 05:12 AM
                                    • Forest79
                                      by Forest79
                                      07-23-2023, 07:39 AM
                                    • maanee11
                                      Help to get Lenovo BIOS bin file for Thinkpad T560
                                      by maanee11
                                      Hello Everyone,
                                      I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                                      https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                                      In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                                      05-15-2022, 11:59 AM
                                      HP ProBook 4540s 4000 Specification for Upgrade or Repair
                                      This specification for the HP ProBook 4540s can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 4540s boardview and 4540s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ProBook 4540s is accurate,...
                                      09-06-2024, 05:27 AM
