Asus U31SD BIOS Dump
  • Anritsu
    • Aug 2017
    • 3
    The layout is,
    00000000:00000fff fd
    00180000:003fffff bios
    00001000:0017ffff me
    I used a buspirate and flashrom utility.
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Asus U31SD BIOS Dump
    here you go
    Im Back... sort of...
    • decayed.cell
      • Sep 2018
      • 11
      Originally posted by ala_borbe
      here you go
      Thanks. Worked for me when (in hindsight a bad idea) Winflash crashed during a BIOS update
      • USARMY
        • Jan 2020
        • 4
        • US
        Work well tnk you
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • Anchar777
          ASUS P1412CE need BIOS DUMP
          by Anchar777
          Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
          06-26-2025, 03:39 AM
