Asus U31SD BIOS Dump
  • Anritsu
    • Aug 2017
    The layout is,
    00000000:00000fff fd
    00180000:003fffff bios
    00001000:0017ffff me
    I used a buspirate and flashrom utility.
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Asus U31SD BIOS Dump
    here you go
    Im Back... sort of...
    • decayed.cell
      • Sep 2018
      • 11
      Originally posted by ala_borbe
      here you go
      Thanks. Worked for me when (in hindsight a bad idea) Winflash crashed during a BIOS update
      • USARMY
        • Jan 2020
        • US
        Work well tnk you
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • pirati
          by pirati
          10-27-2025, 04:20 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
