Thinkpad l560 bios bin
  • rager007
    • Feb 2016
    • 106
    • Usa
    Re: Thinkpad l560 bios bin
    Originally posted by huss584
    Thank you it try this it work 100%
    NO start no Screen !
    • rbvndonh
      • Mar 2021
      • 162
      • B
      On attached BIOS laptop won't turn. There is just black screen.
      I tried cleaning ME, but situation was same.
      I tried also other dump from forum (this one: https://www.badcaps.net/forum/showpo...32&postcount=2) with clean ME, laptop works, but my idea of changing MAC adres didn't work out, as maybe something more require to be changed?
      I found MAC here:
      00829A40 as FE 45 96 FF FE 69 1D 30
      00001000 and 00002000 as FC 45 96 69 1D 30
      8025F4 and 8299F4 as 46 00 43 00 34 00 35 00 39 00 36 00 (or F�C�4�5�9�6�6�9�1�D�3�0)
      In HEX it looks like normal DOT's but it isn't.
      I've tried changing ME region into Consumer and Corporate, but still LAN card is visible as unable to switch on.
      • hoaca388
        Badcaps
        • Jan 2022
        • 11815
        I found MAC here:
        L560 Laptop (ThinkPad) - Type 20F1 - Model 20F1S0UF00
        • rbvndonh
          • Mar 2021
          • 162
          • B
          Thank you Don't know how you do it, but LAN start to work.
          It's other BIOS version or other ME region?
          I found at this link there is in HEX 0088F200 Windows KEY.
          I neet to transfer my one. Do you think it's just about to copy 0088F200 - 0088F260 to add key to bios?
          • hoaca388
            Badcaps
            • Jan 2022
            • 11815
            In the file w25q128fv_bad.bin there is no windows key.
            • rbvndonh
              • Mar 2021
              • 162
              • B
              #26
              I have other damaged board from L570 with key. I want to move key to this board. Could you help making XXXXX- and i will paste my key later? Don't want to use public key or make my one public.
                • 21040
                You can copy it in ok ,everything after the right arrow >
                • rbvndonh
                  • Mar 2021
                  • 162
                  • B
                  #28
                  This didn't work out. It shows no OA2 key.
                  I was looking that newest BIOS hide CD-KEY, maybe it's necessary to downgrade BIOS to older version and then add key or this operation require to change bigger part of BIOS.
                  i've tried downgrade BIOS to 1.42 (in such i see KEY, but 1,57 start hiding keys).
                  edit:
                  i found also at 0019BDC0 somethink about WIN key. Need to analyze WIN and NON-WIN BIOS...
                    • 21040
                    edit:
                    Try the lenovo hardware maintenance disk
                    • rbvndonh
                      • Mar 2021
                      • 162
                      • B
                      #30
                      i don't see any option to add Win key in Lenovo disk. There are just some motherboard related keys to add, or i'm blind
                      Attached is working BIOS, started-up after ME cleaning, but still LAN don't work on this one.
                      Do you know how to combine both BIOS to have WIN key and LAN working?
                      Thank you
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11815
                        #31
                        Thank you
                        It doesn't have windows key
                        • rbvndonh
                          • Mar 2021
                          • 162
                          • B
                          #32
                          i hide it with XXXX to not make my own key public.
                          • rbvndonh
                            • Mar 2021
                            • 162
                            • B
                            #33
                            I compare Bios with OK LAN and NOT OK LAN in Lenovo Diagnostic Tool.
                            Looks like there is other index / slot of PCIe, so maybe BIOS is adressing wrong hardware?
                            EDIT:
                            Fond this possile to change in FIT, attached pic.
                            will change and maybe will work.
                            EDIT2:
                            After changed in FIT PORT5 to PORT3 LAN work again
                            Thank you for all hints and support!
                            • roberto123456
                              • Aug 2022
                              • België
                              #34
                              Hi
                              I'm new on this forum and the problem I have, is that the master bios password is not known.
                              Enclosed the bin file of my bios. Can someone help me to remove password or tell me how to do that.
                              • Dan20701
                                • Sep 2020
                                • 199
                                • United Kingdom
                                #35
                                Hello, I think I have a corrupted bios, Its not turning on and fan
                                is spinning, Its the original bios the chips has been taken off I have
                                not used a clip, Would someone be kind enough to have a look
                                please. Thanks so much.
                                • Markus1741
                                  • Sep 2020
                                  • 846
                                  • N/A
                                  #36
                                  Hello try it ...
                                  • Dan20701
                                    • Sep 2020
                                    • 199
                                    • United Kingdom
                                    #37
                                    Thanks mate, Will give this a go on Monday, Will give an update.
                                    • Dan20701
                                      • Sep 2020
                                      • 199
                                      • United Kingdom
                                      #38
                                      Just a blank screen on this one mate, Thanks for trying.
                                      • Hachem25
                                        • Aug 2021
                                        • 45
                                        • algeria
                                        #39
                                        i have lenovo thinkpad l560 that turns on takes only 60ma and black screen, that happend after update.
                                      • Hachem25
                                        • Aug 2021
                                        • 45
                                        • algeria
                                        #40
                                        sn: MP132B5H
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • MaxonDomkrat
                                          Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                                          by MaxonDomkrat
                                          Hi everyone.
                                          I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                                          07-30-2025, 01:27 PM
                                          Lenovo ThinkPad L560 Notebook L Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad L560 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L560 boardview and L560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                          09-06-2024, 06:00 AM
                                        • 1g0r
                                          Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                          by 1g0r
                                          First, the data in brief:
                                          Manufacturer: Lenovo
                                          Model: ThinkPad L15 G3 21C3-0016GE
                                          motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                          IC Bios 1: MX77L25650F
                                          IC Bios 2​: MX25L25673G
                                          EC Chip: NPCX997KAABX
                                          So far I've been a silent reader, but now I need your help
                                          I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                          I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                          The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                          01-18-2025, 02:39 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
