Thinkpad l560 bios bin
  • medinfo
    • May 2016
    • 331
    • Morocco
  • medinfo
    • May 2016
    • 331
    • Morocco
    Re: Thinkpad l560 bios bin
    Plzz
    • medinfo
      • May 2016
      • 331
      • Morocco
      Up
      • dr_laptop05
        • Apr 2015
        • 8
        • romania
        Lenovo Thinkpad L560 (AILL1/L2 LA-C421P rev:1.0)
        • magneh
          • Apr 2014
          • 607
          • Portugal
          Hi there,
          Quick question, is it possible to remove a BIOS pwd with this dump?
          Thanks!
          • iyori20
            Banned
            • Nov 2018
            • 43
            • maroc
            merci b
            • [l3go]psycho viking
              • May 2020
              • 6
              • Denmark
              Rebuild broken UEFI/BIOS for Lenovo L560
              Can someone help me rebuild my BIOS?
              During bios update the computer shut down and have not been able to boot since.
              I have desoldered the bios chip and saved a backup of what was on it.
              I have tried loading several bios images i have found, but without luck. Some results in black screen and 100% fan speed. Other results in the computer just lighting the power button, as if it was, on but nothing else happens.
              I did try to rebuild my bios dump, using UEFITOOL and the bios update file for the same version as my bios was, without luck. I am not very experienced in rebuilding bios or playing around with UEFITOOL.
              Mostly limited to removing passwords.
              For each try, i did also read the data out of the chip after programming it, to validate that everything was written correctly.
              Please help me out, and if you now of a good guide of how to rebuild/play around with UEFI, please let me know
              Last edited by [l3go]psycho viking; 06-29-2020, 09:59 AM. Reason: spelling mistakes
              • bachir2004
                • Feb 2015
                • 439
                • maroc
                Re: Rebuild broken UEFI/BIOS for Lenovo L560
                Will this help?
                https://www.youtube.com/watch?v=GUbG740BDYQ
                  • May 2020
                  • 6
                  • Denmark
                  Thanks, but i don’t think i am experienced enough to understand what to do with it.
                  From looking into my dump, i can see that the ME version is the newest, but when trying to use MEAnalyzer it fails, which tells me that the computer crashed during the ME flash.
                  Looking into the bios version, i can see that this is a lot older version, telling me that the computer did not get started flashing the BIOS region.
                  Though i am not sure about above at all, and if my thinking is correct.
                  I would be very grateful for some inputs before programming the chip again, as i have been de- and resoldering the chips so many times now, that the soldering pads are beginning to get “tired of me”
                  When trying to flash with a full BIOS dump from another system, and it does not work, is that because of conflicts with KBC? From what i can see, the BIOS and ME is in the same chip, at least on this laptop.
                  Does my laptop model use KBC?
                  I have also tried using Hex editor to replace the entire bios region and ME region, to be sure that the versions og each plays well, and correcting the SN and windows product code.
                  Still, no luck.
                  Is it possible that i just need to find a clean ME image in the right version and replace the ME region in my BIOS dump?
                  I figure that the right ME version will not be the one in my current dump, but the one that should match the older bios?
                  Sorry, a lot of questions. I hope i don’t confuse anyone. I am just trying to understand what i am playing with..
                    • May 2020
                    • 6
                    • Denmark
                    Originally posted by bachir2004
                    Ok, i gave it a shot, after seeing the video.
                    I found the correct older ME version and used the Bios Image Tool to vreate a new version of my bios, replacing the ME section with the clean one, but without luck.
                    2 solder pads are loose now, arrrghh
                    • bachir2004
                      • Feb 2015
                      • 439
                      • maroc
                      try the first one and see.
                        • May 2020
                        • 6
                        • Denmark
                        Thanks a lot for your time, though it did not work. I have given up on the motherboard. Wasted too much time on it now.
                        • joby91
                          • Sep 2018
                          • 43
                          • german
                          Hello together,
                          i have tried many bios files but with all of them i get black screen and fan spinning 100%.
                          With the native Bios i got 5 beeps.
                          Does anyone have another bios files for me to try?
                          • qayyum786
                            • Aug 2018
                            • 1959
                            • INDIA
                            post your original backup
                            • iyori20
                              Banned
                              • Nov 2018
                              • 43
                              • maroc
                              thanks
                              • mgutzeit
                                • Jun 2021
                                have the same problem... Thinkpad L560 Model 20F1-001YGE. When i flash the file (with success) i get only blank screen and Fan turning at full speed. The Lenovo Files are only FL1 Files which i could not directly use i guess... Does anyone have the matching BIN File for this machine ? I do not have a backup of the original BIOS/UEFI file
                                  • 21677
                                  try this one https://www.badcaps.net/forum/showpo...32&postcount=2
                                  • mgutzeit
                                    • Jun 2021
                                    Hi... Unfortunately this does not work also. Maybe that the board has a bigger problem than the BIOS. The board ist marked with AILL3... Does the BIOS fit to this as well ? i have often seen that the BIOS is matchting the AILL2 version
                                    • huss584
                                      Hussein
                                      • Apr 2020
                                      • 229
                                      • Palestine
                                      Need to Cleare my BIOS dump, attached her
                                      the Problem No bootable drive are shown in UEFI,OR Lecacy , usb ,HHD .. etc
                                      PHP Code:
                                      [ATTACH]249581[/ATTACH
                                      • huss584
                                        Hussein
                                        • Apr 2020
                                        • 229
                                        • Palestine
                                        Originally posted by SMDFlea
                                        Thank you it try this it work 100%
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • MaxonDomkrat
                                          Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                                          by MaxonDomkrat
                                          Hi everyone.
                                          I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                                          07-30-2025, 01:27 PM
                                          Lenovo ThinkPad L560 Notebook L Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad L560 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L560 boardview and L560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                          09-06-2024, 06:00 AM
                                        • 1g0r
                                          Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                          by 1g0r
                                          First, the data in brief:
                                          Manufacturer: Lenovo
                                          Model: ThinkPad L15 G3 21C3-0016GE
                                          motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                          IC Bios 1: MX77L25650F
                                          IC Bios 2​: MX25L25673G
                                          EC Chip: NPCX997KAABX
                                          So far I've been a silent reader, but now I need your help
                                          I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                          I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                          The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                          01-18-2025, 02:39 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
