HP ProBook 650 G2 6050a2723701-mb-a02
  • rishpin
    • Dec 2015
    • 15
    • kuwait
    #181
    Re: HP ProBook 650 G2 6050a2723701-mb-a02
    this bios me error late display and no boot anyone clean please
    • qayyum786
      • Aug 2018
      • 1933
      • INDIA
      #182
      clear
      • USMAN.KHAN
        • Sep 2014
        • pakistan
        #183
        Originally posted by gecon27
        Update:
        I managed to successfully flash BIOS, first on a HP ProBook 650 G2 (chip Winbond 25Q128FVSQ) and then on a HP ProBook 650 G1 (chip Macronix MXIC MX25L12873F), using in both cases the firmwares provided by SMDFlea.
        I include hereafter some notes based on my own experience:
        1) Neoprogrammer seems to do the work better than CH341A Programmer and AsProgrammer. Using the latter two you have to be very cautious which version of the software you will use in order to correctly support the chip(s) you're using.
        2) In both cases I did the reprogram with the chips on board. It is important to make sure that the machine is completely switched off by pressing the power-off button for 10 seconds or so before starting the programming. For the chips to be recognized, in my case at least the charger had to be unplugged.
        3) I downloaded DMI Tool 2.018.zip from https://drive.google.com/file/d/16XT...bjoay8pAx/view and created a bootable USB stick as per the instructions. Then I booted from this USB and followed the instructions to restore the parameters from the backup I had taken with the HP BCU utility before starting the programming (note: all parameters had to be typed in manually) and finally commit. Attached some screenshots.
        please some one update link google link not found
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #184
          Use the forum search engine before posting
          https://www.badcaps.net/forum/showthread.php?t=69204
          Become a Badcaps supporter
          Thanks to all supporters.
          • JustRepairing
            • Mar 2023
            • 8
            • pakistan
            #185
            Re: bios hp probook 650 g2
            not working fan runing fast
            have biose password plz clear anyone
              • 21404
              Read post #179
              • simike19
                • Jul 2023
                • hungary
                #187
                hello. can someone fix my bios?
                  • 21404
                  Please read the rules before posting.
                  • dqtech
                    Badcaps
                    • Jul 2018
                    • 632
                    • N/A
                    #189
                    thanks
                    • apostsamking
                      • Dec 2017
                      • 118
                      • Ghana
                      #190
                      I Have Hp circus 6050a2723701 mb a02 powers on no display. Pls can you fix the bios for me. SN 5CG6316M0F BOARD NO. CIRCUS 6050A2723701 MB A02
                    • apostsamking
                      • Dec 2017
                      • 118
                      • Ghana
                      #191
                      • rex98
                        • Feb 2023
                        • 1287
                        • Mandaue CEBU, Philippines
                        #192
                        try.
                        i just clear me.
                        • iyori20
                          Banned
                          • Nov 2018
                          • 43
                          • maroc
                          #193
                          tank you
                          • hamza hamza
                            • May 2022
                            • 28
                            • morocco
                            #194
                            i have admin password anybody can help plz
                          • SAF1
                            • Sep 2022
                            • 6
                            • Ghana
                            #195
                            HP ProBook 640 G2 original bios dump and boardview needed, can anyone help
                          • FZG
                            • Sep 2022
                            • 111
                            Can someone please take a look at this bios? The board does not power on at all but voltages are present (19V/5V/3.3V/1.8V).
                            I already tried to put together a fresh bios with the existing ME but it did not solve the problem so I guess I must have done it wrong.
                            HP 650 G2
                            6050A2723701-MB-A02
                            SN: 5CG6451VRL
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12061
                              #197
                              HP 650 G2
                              6050A2723701-MB-A02
                              SN: 5CG6451VRL
                              HP ProBook 650 G2 Base Model Notebook PC
                              • FZG
                                • Sep 2022
                                • 111
                                Thanks! Board is still not working, it probably has other problems. When I plug in the power adapter it idles at 0.015A and briefly jumps to 0.200A when pressing the power button but it goes down again immediately. Keeping the power button pressed heats up an IC which is likely the 3.3V LDO. Should I replace the IC or does it indicate a problem with the EC or PCH?
                                  SMDFlea commented
                                  Editing a comment
                                  If its no longer a bios related issue start a new thread in the laptop troubleshooting forum.
                              • habib_7_7
                                • Nov 2015
                                • 14
                                • pakistan
                                #199
                                try...
                                this bios for those who lost original data
                                • Jnmbc20
                                  • Jan 2020
                                  • 13
                                  • Kenya
                                  #200
                                  Hello everyone, I have a Hp probook 650 G2 that is working well, problem is, it switches on the fan when the laptop have been shutdown. This will run till the battery drains. I have tried flashing with BIOS downloaded from here but it doesn't display anything.
                                  When i "borrow" BIOS from a similar motherboard, it doesnt power, or when it powers, no display.
                                  Attached is the original bios dump. Any help is welcome.
                                  PS: I'm trying to find time to read about BIOS ME etc, between my workshop hours, hoping to succeed.
                                • studdy05
                                  Bricked HP Probook 450 G7 Bios questions
                                  by studdy05
                                  Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                  Ive got...
                                  07-08-2025, 09:24 PM
                                • intelg
                                  HP Elitedesk 800 G6 lost BIOS admin password
                                  by intelg
                                  Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                  Here is the hardware identification specs:
                                  HP EliteDesk 800 G6 Desktop Mini PC
                                  Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                  BIOS ver S21 Ver. 02.05.01 01/05/2021
                                  Born on date: 07/26/2021
                                  SN MXL11841GN
                                  SKU 3X8V9UCHABA
                                  UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                  SYSTEM BOARD ID 8710
                                  SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                  11-03-2023, 02:05 AM
                                • Phad
                                  Seeking help and advice to remove bios admin password – HP ProBook 4520s
                                  by Phad
                                  Dear All,
                                  Hope that this post is at the right place of the forum.
                                  I am seeking help and technical advice to remove bios admin password from HP ProBook 4520s.
                                  The laptop is operating normally and, I am not facing any major issue with it except; the bios admin password that I found about by coincidence only few weeks back.
                                  As the laptop is operating normally, I am reluctant to take it to a workshop to de-solder the bios chip in order to read it by an external programmer, as I am not an expert in doing such a thing.
                                  After...
                                  11-10-2021, 12:05 AM
                                • macabook
                                  by macabook
                                  🧩 Initial Issue
                                  07-24-2025, 02:17 PM
                                  by Vesko356
                                  08-11-2023, 03:27 AM
