Asus x540s bios
  • baddjavo
    • Jun 2018
    • 88
    • Serbia
    Re: Asus x540s bios
    After connect dc all voltages are present for 3sec, sometime 1 sec, sometimes nothing. I dont know if is bios problem but iam posting original bios.
    motherboard is x540sa rev:2.1
    • Mazorca
      • Jan 2017
      • 463
      Re: Asus x540s bios
      Your DMI region can't be found, nor the windows keys, are you sure this is your original? The BIOS Region from UEFITool extracted from your BIN file and Asus Update are identical. Anyway, try this file.
      • baddjavo
        • Jun 2018
        • 88
        • Serbia
        Re: Asus x540s bios
        Laptop came to me for repair, dunno if someone else changed bios. I took bios using ch341a black directly from chip. Tried your new bin and same results. After dc plug-in one led lit, then other one, two times, after that nothing happens.
        • Uno qualsiasi
          • Aug 2022
          • Italy
          Re: Asus x540s bios
          Hi, I have downloaded all three bios files reported and uploaded, flashed them into the eprom but nothing the motherboard flashes but won't start. At this point the questions come to me and that is, am I doing something wrong? And if so, what? Are the bios uploaded on the forum pure and therefore need to be "adapted" to the pc on which one would like to flash it? And if so what programs could you advise me to do this i.e. to "adapt" them?
          • peste
            • 13431
            • ROMANIA
            Re: Asus x540s bios
            post the original bios of the laptop and pictures of the stickers from the ram memory area..
            read this..
            • Uno qualsiasi
              • Aug 2022
              • Italy
              #26
              Re: Asus x540s bios
              read this..
              unfortunately, the original bios I can't load because the eprom burned out and I had to buy the new chip, obviously blank. The chip type is a 25LQ64 gigadevice. The bios type is x540saa on asus x540sa rev. 2.1 motherboard.
              As for "send images of the ram memory area stickers..." I didn't quite understand what you mean, can you explain further? Thank you.
              • lapfix
                • Mar 2020
                • 2756
                • my workshop
                #27
                Re: Asus x540s bios
                There s a sticker at or near memory slot , we need the informations write on it
                • Uno qualsiasi
                  • Aug 2022
                  • Italy
                  #28
                  Re: Asus x540s bios
                  These in the zipper archive only the photos of the motherboard since the ram memory (4gb) is soldered on it. The only label on it is the one in the picture.
                  • lapfix
                    • Mar 2020
                    • 2756
                    • my workshop
                    #29
                    Re: Asus x540s bios
                    Try
                    • 4shans
                      • Jul 2019
                      • Srilanka
                      #30
                      Re: Asus X540SA bios
                      hello everyone
                      need help , can anyone make a ME Clean bios of file that i attached
                      thanks in advanced
                      • hardware1
                        • Sep 2021
                        • 2946
                        • N/A
                        #31
                        Originally posted by 4shans
                        hello everyone
                        thanks in advanced
                        Your device has a something called TXE Not ME, because your CPU is an Atom.
                        It should be clean now.
                        all donations are welcome,
                        • SergAN2
                          • Jul 2017
                          • 13
                          • Russia
                          #32
                          Re: Asus x540s bios
                          Hello! Please help me. BIOS password and clear TXE. Thanks
                          • lapfix
                            • Mar 2020
                            • 2756
                            • my workshop
                            #33
                            Re: Asus x540s bios
                            Try and give feedback
                            • SergAN2
                              • Jul 2017
                              • 13
                              • Russia
                              #34
                              Re: Asus x540s bios
                              Thanks. Your dump witout DMI and Windows Key
                              • hardware1
                                • Sep 2021
                                • 2946
                                • N/A
                                #35
                                Re: Asus x540s bios
                                Try this Password: 123567
                                Why you want to clean TXE Region?
                                • SergAN2
                                  • Jul 2017
                                  • 13
                                  • Russia
                                  #36
                                  Re: Asus x540s bios
                                  Thanks a lot!!! 123567 - works))
                                  About TXE - new CPU SR29E installed. May be it isn`t needed.
                                  • hardware1
                                    • Sep 2021
                                    • 2946
                                    • N/A
                                    #37
                                    Re: Asus x540s bios
                                    Here's your dump file with TXE Clean, try it.
                                    • StreamLand
                                      • Apr 2025
                                      • Baku
                                      #38
                                      Asus x540s bios could you help me find bios for model QCWB335
                                        • 21679
                                        post S/N, full name and model, motherboard model, etc.
                                        post the contents of the bios chip even if it is corrupted..
                                        read the forum rules..https://www.badcaps.net/forum/troubl...ore-posting​
                                        • StreamLand
                                          • Apr 2025
                                          • Baku
                                          #40
                                          S/N GBN0GR029588474
                                          Model: X540SA-XX400D
                                          Version 302
                                          Vbios Version 1007.I18x540saa.001
                                          EC version F0BS0500
                                          I am trying 302 and 304 but it says wrong version
                                          • razor_amd
                                            by razor_amd
                                            12-15-2020, 07:07 PM
                                          • grimacelord
                                            by grimacelord
                                            07-10-2025, 02:52 PM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • throwaway327
                                            by throwaway327
                                            Model No: RC72LA
                                            Serial No: SBNVKD001014459
                                            06-18-2025, 05:52 PM
                                          • lrouw84
                                            Asus vivobook s510ua bios changed to x510un
                                            by lrouw84
                                            Hi there,
                                            I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                                            I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                                            01-28-2023, 01:31 PM
