bios dump for motherboard asus G750JZ REV 2.0
  • danieltoader69
    • Apr 2013
    • 39
    • romania
    Hy my friend
    I need main bios dump for asus G750J motherboard G750JZ REV 2.0.No picture possible video but first i try to reflash bios
    Thanks in advance
  • yashjovi
    • Nov 2011
    • 130
    Re: bios dump for motherboard asus G750JZ REV 2.0
    Asus G750JZ Rev. 2.0 Bios
    • danieltoader69
      • Apr 2013
      • 39
      • romania
      thanks !!!!!!! Yashjovi
      Reflash and post result
      • danieltoader69
        • Apr 2013
        • 39
        • romania
        Hi Yashjovi! Sorry for delay .Reflash bios but laptop does not work , IT 8585 is problem
        Thanks again
        • palady
          • Jan 2014
          • 21
          • si
          Working ok. Thanks
          • glovecaps
            by glovecaps
            11-25-2024, 04:23 PM
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • GardevoirForEver
            Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
            by GardevoirForEver
            I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
            Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
            The motherboard of my ASUS...
            11-15-2025, 04:30 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
