Hi, need bios bin file for Dell E6420 LA-6591P- P15G001
					Dell e6420 bios
Re: Dell e6420 bios
Here
Dell Latitude E6420 PAL50 LA-6591P
BIOS U52, U53
Techman1025Attached Files -
Re: Dell e6420 bios
thanks, but when power button press, power led light for 8-10 seconds and cuts off. Intermittent 3v coming to bios chip u52 u53. When i remove U53 , Q55 1,2,3,5,6,7-3V and pin 4- 15v, but fan spin for 7-8 sec and power off.But when insert U53 no volts on Q55 pin 1,2,3,4Comment
Every donation made will go towards server fees and maintenance costs.Comment
Need bios for Latitude E6420 PAL50 LA-6591P rev 1.0(A00)
I get a MB Latitude E6420 PAL50 LA-6591P LA-5691P rev 1.0. It still works but whenever it boots, there is a message saying: ME is in recovery state. In general it works but not stable..
I tried to dump bios and clear me with tool Intel Easy Clear Me, database with latest update but problem not solved.
Then I tried this bios but it not work.
Please help.
Here is my old dump biosAttached FilesComment
Re: Need bios for Latitude E6420 PAL50 LA-6591P rev 1.0(A00)
Use "Search this Forum" option:
https://www.badcaps.net/forum/showpo...97&postcount=3
https://www.badcaps.net/forum/showpo...8&postcount=13----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Re: Dell e6420 bios
can someone clear my bios dump,, laptop no display, bios above not workingAttached FilesComment
Re: Dell e6420 bios
try..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Re: Dell e6420 bios
Clean me, tested, latest versionAttached FilesComment
Good evening
I no longer have access to bios
Can anyone redo the bios for me please?
Thank you so much​Attached FilesComment
You must post the service tag/serial number with every bios request.If there is a related thread topic already post there,you do not have to start a new thread
You MUST:- Post under a related thread if it exists
 - Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://badcaps.net/forum/showthread.php?t=88758 )
							Channel: BIOS Requests ONLY!
			by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
			by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
			by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
			by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
 - Loading...
