HP Probook 450 G0 bios dump please
  • sopik78
    • Nov 2013
    • 517
    • Czech Republic
    Friends, can somebody post HP PROBOOK 450 G0 FiJi MB-12238-1 (48.4YZ31.001) bios dump please.
    It would be very helpful for me.
    Thanks.
  • Me.Orouji
    • Dec 2015
    • 117
    • Iran
    Re: HP Probook 450 G0 bios dump please
    • sopik78
      • Nov 2013
      • 517
      • Czech Republic
      thanks a lot!
      • Me.Orouji
        • Dec 2015
        • 117
        • Iran
        Your welcome
        • Pascal Komlassan
          • Jan 2017
          • 805
          • TOGO
          Originally posted by Me.Orouji
          Good
          • gitsfarmaz
            Professnal tech
            • Apr 2017
            • 30
            • Kenya
            greetings guys, can anyone help me clean up the bios of hp probook 450 g1 bios bin with password and fingerprint...thanks in advance
            • dycc
              Vision
              • Nov 2011
              • 624
              • Côte d'Ivoire
              TRY THIS
              first boot hit F10 to enter the BIOS area and you'll be asked if you would like to access the BIOS as a GUEST. Say "yes" and on the first screen you'll see the option to set the new BIOS Admin Password
              • dycc
                Vision
                • Nov 2011
                • 624
                • Côte d'Ivoire
                Or this
                • vovniko
                  • Dec 2016
                  • 8
                  • Georgia
                  hello . if u have from hp 470 G0 bios dump . i cant find ((.
                  • Marco_compucell
                    • Feb 2012
                    • 63
                    • South Africa
                    Thank You
                    • khalils
                      • Mar 2017
                      • pakistan
                      Thanks alot
                      • boussaa islem
                        • Nov 2018
                        • 30
                        • ALGRIA
                        thank you very much friends for all
                        • boussaa islem
                          • Nov 2018
                          • 30
                          • ALGRIA
                          Re: HP Probook 450 G0 bios tested version
                          450 G0 bios
                          • boussaa islem
                            • Nov 2018
                            • 30
                            • ALGRIA
                            i went send somme file bios but i can't
                            pleas how methode for sending
                            help and thanks
                              • 20288
                              help and thanks
                              Click on the "Go Advanced" button below the message box,then click on "Manage Attatchments"
                              • boussaa islem
                                • Nov 2018
                                • 30
                                • ALGRIA
                                thank you i try this methode but my file not upload
                                  • 20288
                                  Use winrar or 7-zip to zip the file. See the file extensions that are supported.
                                  • salki
                                    • Jul 2017
                                    • 3
                                    • Croatia
                                    Hallo,
                                    Today after I have listened your advice and experience, successfully repaired HP Probook 450 G0.
                                    The symptoms were the following:
                                    1. Black screen - no video.
                                    2. Continuously blinking caps lock
                                    3. The fan turned on the strongest
                                    4. The WLAN and WLAN indicator light is yellow.
                                    Solved:
                                    1. Dissasembly laptop,
                                    2. Using the hot air, I removed the bios chip.
                                    3. Using the Flash programmer I removed the old bios. -
                                    4. I replaced a Winbond W25Q64F chip with another 8 MB (I tried to put your DUMP bios and a couple of others that you put but did not work) I programmed it with the old BIOS that I removed from the BIOS chip.
                                    Solder chip back to motherboard.
                                    Tested motherboard- working, compose a laptop.
                                    The motherboard worked, just needed to enter BIOS settings with F10 and return to Default, later I downloaded the new BIOS version from the official station and installed it.
                                    Everything works great. Thank you for your helpful advice.
                                    • kammy6000
                                      • Oct 2012
                                      • 22
                                      HELLO ,members thankyou for your support
                                      i have hp probook 450
                                      same symptoms were the following:
                                      2. The fan turned on the strongest
                                      3. The WLAN and WLAN indicator light is yellow.
                                      4,bios battery is 3v
                                      5.bios used (bios hp probook 450 go.rar)
                                      flashed bios and was successful , powered on to some options , shutdown the pc for the night ,next day was back to black screen again ! flashed again bios with programmer now wont fix itself just stays black screen with fan at full speed
                                      tested ram is ok
                                      tested on external display nothing a
                                      any ideas ? thanks
                                      • peste
                                        • Dec 2016
                                        • 12230
                                        • ROMANIA
                                        try bios from post # 18
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • solomost
                                          need bios dump for HP ProBook 640 G2
                                          by solomost
                                          HI I need bios dump for HP ProBook 640 G2 PLZ☺☺
                                          prblm: black screen caps lock blinking 5 times then fan spening
                                          CT: PFKCT00WB69310 REV : 1.20
                                          motherboard : HSB J Mv-6 94v-0 E89382
                                          03-21-2025, 06:22 AM
                                        • ktcar214
                                          Need help for HP ProBook 445R G6 Secure boot key removal from BIOS dump
                                          by ktcar214
                                          Hello.
                                          I tried to add a custom secure boot key (for secure booting Linux) to my bios, but after this, my laptop bricked. After adding secure boot key (via PowerShell) and enabling secure boot my laptop turns on, shows HP logo, and after 5 seconds it turns off and on, and it repeats forever.
                                          My goal is to either turn off secure boot or remove my custom key from BIOS dump.
                                          I'll attach my bios dump (version R79_011700) from my bios chip 25b127dsig, my keys (PK/KEK/db), and bios dump from another HP ProBook 445R G6(I found it on this forum. URL: https://www.ba...
                                          12-07-2021, 08:57 AM
                                        • grimacelord
                                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                          by grimacelord
                                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                          Motherboard model number: DA0PAMB46A1 REV: A
                                          Secondary motherboard model number: 0PAB
                                          SKU: 685K4UA
                                          Serial number is: 5CD3223BJP
                                          Recently reflashed this laptop with latest BIOS and once...
                                          05-07-2024, 08:06 AM
