HP Probook 450 G0 bios dump please
    Friends, can somebody post HP PROBOOK 450 G0 FiJi MB-12238-1 (48.4YZ31.001) bios dump please.
    It would be very helpful for me.
    Thanks.
    Re: HP Probook 450 G0 bios dump please
      thanks a lot!
        Your welcome
          Originally posted by Me.Orouji View Post
          Good
            greetings guys, can anyone help me clean up the bios of hp probook 450 g1 bios bin with password and fingerprint...thanks in advance
              TRY THIS
              first boot hit F10 to enter the BIOS area and you'll be asked if you would like to access the BIOS as a GUEST. Say "yes" and on the first screen you'll see the option to set the new BIOS Admin Password
                Or this
                  hello . if u have from hp 470 G0 bios dump . i cant find ((.
                    Thank You
                      Thanks alot
                        thank you very much friends for all
                          Re: HP Probook 450 G0 bios tested version
                          450 G0 bios
                            i went send somme file bios but i can't
                            pleas how methode for sending
                            help and thanks
                              help and thanks
                              Click on the "Go Advanced" button below the message box,then click on "Manage Attatchments"
                                thank you i try this methode but my file not upload
                                  Use winrar or 7-zip to zip the file. See the file extensions that are supported.
                                    Hallo,
                                    Today after I have listened your advice and experience, successfully repaired HP Probook 450 G0.
                                    The symptoms were the following:
                                    1. Black screen - no video.
                                    2. Continuously blinking caps lock
                                    3. The fan turned on the strongest
                                    4. The WLAN and WLAN indicator light is yellow.
                                    Solved:
                                    1. Dissasembly laptop,
                                    2. Using the hot air, I removed the bios chip.
                                    3. Using the Flash programmer I removed the old bios. -
                                    4. I replaced a Winbond W25Q64F chip with another 8 MB (I tried to put your DUMP bios and a couple of others that you put but did not work) I programmed it with the old BIOS that I removed from the BIOS chip.
                                    Solder chip back to motherboard.
                                    Tested motherboard- working, compose a laptop.
                                    The motherboard worked, just needed to enter BIOS settings with F10 and return to Default, later I downloaded the new BIOS version from the official station and installed it.
                                    Everything works great. Thank you for your helpful advice.
                                      HELLO ,members thankyou for your support
                                      i have hp probook 450
                                      same symptoms were the following:
                                      2. The fan turned on the strongest
                                      3. The WLAN and WLAN indicator light is yellow.
                                      4,bios battery is 3v
                                      5.bios used (bios hp probook 450 go.rar)
                                      flashed bios and was successful , powered on to some options , shutdown the pc for the night ,next day was back to black screen again ! flashed again bios with programmer now wont fix itself just stays black screen with fan at full speed
                                      tested ram is ok
                                      tested on external display nothing a
                                      any ideas ? thanks
                                        try bios from post # 18
