HP Probook 450 G0 bios dump please
  • sopik78
    • Nov 2013
    • 519
    • Czech Republic
    Friends, can somebody post HP PROBOOK 450 G0 FiJi MB-12238-1 (48.4YZ31.001) bios dump please.
    It would be very helpful for me.
    Thanks.
  • Me.Orouji
    • Dec 2015
    • 117
    • Iran
    Re: HP Probook 450 G0 bios dump please
    • sopik78
      • Nov 2013
      • 519
      • Czech Republic
      thanks a lot!
      • Me.Orouji
        • Dec 2015
        • 117
        • Iran
        Your welcome
        • Pascal Komlassan
          • Jan 2017
          • 809
          • TOGO
          Originally posted by Me.Orouji
          Good
          • gitsfarmaz
            Professnal tech
            • Apr 2017
            • 30
            • Kenya
            greetings guys, can anyone help me clean up the bios of hp probook 450 g1 bios bin with password and fingerprint...thanks in advance
            • dycc
              Vision
              • Nov 2011
              • 625
              • Côte d'Ivoire
              TRY THIS
              first boot hit F10 to enter the BIOS area and you'll be asked if you would like to access the BIOS as a GUEST. Say "yes" and on the first screen you'll see the option to set the new BIOS Admin Password
              • dycc
                Vision
                • Nov 2011
                • 625
                • Côte d'Ivoire
                Or this
                • vovniko
                  • 10
                  • Georgia
                  hello . if u have from hp 470 G0 bios dump . i cant find ((.
                  • Marco_compucell
                    • Feb 2012
                    • 75
                    • South Africa
                    Thank You
                    • khalils
                      • Mar 2017
                      • pakistan
                      Thanks alot
                      • boussaa islem
                        • Nov 2018
                        • 30
                        • ALGRIA
                        thank you very much friends for all
                        • boussaa islem
                          • Nov 2018
                          • 30
                          • ALGRIA
                          Re: HP Probook 450 G0 bios tested version
                          450 G0 bios
                          • boussaa islem
                            • Nov 2018
                            • 30
                            • ALGRIA
                            i went send somme file bios but i can't
                            pleas how methode for sending
                            help and thanks
                              • 22127
                              help and thanks
                              Click on the "Go Advanced" button below the message box,then click on "Manage Attatchments"
                              • boussaa islem
                                • Nov 2018
                                • 30
                                • ALGRIA
                                thank you i try this methode but my file not upload
                                  • 22127
                                  Use winrar or 7-zip to zip the file. See the file extensions that are supported.
                                  • salki
                                    • Jul 2017
                                    • Croatia
                                    Hallo,
                                    Today after I have listened your advice and experience, successfully repaired HP Probook 450 G0.
                                    The symptoms were the following:
                                    1. Black screen - no video.
                                    2. Continuously blinking caps lock
                                    3. The fan turned on the strongest
                                    4. The WLAN and WLAN indicator light is yellow.
                                    Solved:
                                    1. Dissasembly laptop,
                                    2. Using the hot air, I removed the bios chip.
                                    3. Using the Flash programmer I removed the old bios. -
                                    4. I replaced a Winbond W25Q64F chip with another 8 MB (I tried to put your DUMP bios and a couple of others that you put but did not work) I programmed it with the old BIOS that I removed from the BIOS chip.
                                    Solder chip back to motherboard.
                                    Tested motherboard- working, compose a laptop.
                                    The motherboard worked, just needed to enter BIOS settings with F10 and return to Default, later I downloaded the new BIOS version from the official station and installed it.
                                    Everything works great. Thank you for your helpful advice.
                                    • kammy6000
                                      • Oct 2012
                                      • 22
                                      • uk
                                      HELLO ,members thankyou for your support
                                      i have hp probook 450
                                      same symptoms were the following:
                                      2. The fan turned on the strongest
                                      3. The WLAN and WLAN indicator light is yellow.
                                      4,bios battery is 3v
                                      5.bios used (bios hp probook 450 go.rar)
                                      flashed bios and was successful , powered on to some options , shutdown the pc for the night ,next day was back to black screen again ! flashed again bios with programmer now wont fix itself just stays black screen with fan at full speed
                                      tested ram is ok
                                      tested on external display nothing a
                                      any ideas ? thanks
                                      • peste
                                        • 13768
                                        • ROMANIA
                                        try bios from post # 18
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • mkdj
                                          by mkdj
                                          Dear all,
                                          10-19-2025, 04:41 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • studdy05
                                          Bricked HP Probook 450 G7 Bios questions
                                          by studdy05
                                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                          Ive got...
                                          07-08-2025, 09:24 PM
                                        • haitham sharabati
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          💀 Problem:😅
                                          08-07-2025, 04:54 AM
