Can someone suggest me a bios programmer (i maybe off topic)
  • sstamenov91
    • Mar 2016
    • 47
    • Bulgaria
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Can someone suggest me a bios programmer (i maybe off topic)
    I use a CH341a as do a few on here also. Plenty to read if you use the search function.
    • techman1025
      • Jun 2014
      • 497
      For what ? I use for laptops a TL866-A with the opt adapters Easy to use & cheap and i've been using it for years noproblem. Around 100.00 with the opt adapters on ebay.
      Techman1025
      • sstamenov91
        • Mar 2016
        • 47
        • Bulgaria
        Techman1025
        yes, for laptops
        • sstamenov91
          • Mar 2016
          • 47
          • Bulgaria
          i have CH341A and some times does not read the chip correctly
          and i want to try with a drifferent programmer
          • piernov
            • Jan 2016
            • 4437
            • France
            Used a Raspberry Pi for SPI ROM in the past. Now I've got the RT809F because I had some computer displays firmware to flash. Works nice with the VGA ISP and has a great support for all kind of SPI/I2C ROM.
            You'll have to buy the PEB-1 extension if you want to flash some EC internal ROM, but I'm not sure the support is very good.
            Also I wanted to flash some PIC but the support is very limited too.
            • jasko_jacker
              • Oct 2014
              • 1140
              • italy
              The best and cheap is EZP2010 not EZP2013 that is a fake.
              This programmer work with all common bios chip , and works with 1.8v chip with
              adaptor.
              If you need to programm old bios and microcontroller see genius G840 .
              RT809F and similar are usefull to programm EC .
              • techcare
                • Nov 2017
                • 18
                • KOREA
                Hi who can give me a rt809f bios programmer installer for windows 7/8/10..Thanks in advance.
                • bachir2004
                  • Feb 2015
                  • 439
                  • maroc
                  https://www.4shared.com/rar/dOJmCtGtei/20170828.html
                  • piernov
                    • Jan 2016
                    • 4437
                    • France
                    http://www.ifix.net.cn/thread-325-1-1.html → Official thread
                    • subroto
                      • Oct 2015
                      • 230
                      • Bangladesh
                      RT809f and Minipro TL866 series are best deal.
                      • sparker1
                        • Sep 2011
                        • 343
                        How do you guys deal with "file is too long" message after extracting a bios from an exe file?
                          • 31161
                          most exe files dont contain a complete bios.
                          • techman1025
                            • Jun 2014
                            • 497
                            (How do you guys deal with "file is too long" message after extracting a bios from an exe file?)
                            First upload the file then i will explain in some cases there are a tail that could just be cut off comparing it to the original bios file ending also some updates not a complete file or some even have the ec and bios togetter and need to be cut out ....some cases not that's why original file is always needed to compare or even needed to cut out the original ME REGION or DMI INFO
                            Techman1025
                            • STKR123
                              The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                              by STKR123
                              Greetings badcaps community,
                              I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                              So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                              Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                              I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                              These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                              I learned that desoldering...
                              10-29-2024, 06:03 AM
                            • hotcrossedbuns999
                              M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                              by hotcrossedbuns999
                              My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                              1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                              2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                              3. I could only locate two chips that look like bios chips. Could someone verify this
                              01-03-2025, 12:32 PM
                            • macabook
                              by macabook
                              🧩 Initial Issue
                              07-24-2025, 02:17 PM
                            • zlr8r
                              looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                              by zlr8r
                              looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                              cheers
                              Dell Inspiron 17 (7786) Laptop
                              Service Tag: 5J0NHT2
                              Bios: 1.9.0
                              MOBO: RO 15 17 WHL 2GB MB / 18706-2
                              Attached;
                              1. My saved bios using a programmer
                              2. Dells Bios updater .exe (v1.16)
                              3. Dells Bios recovery file
                              4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                              5. Image of ME...
                              12-18-2023, 03:08 PM
                            • Vesko356
                              by Vesko356
                              08-11-2023, 03:27 AM
