HP Elitebook 820 G1 - Still BIOS password after flash
  • rioreno
    • Feb 2009
    • 540
    • Indonesia
    Re: HP Elitebook 820 G1 - Still BIOS password after flash
    Originally posted by silversweden
    Here is the main board. The bios is the one upper mid left of the copper ring. There is a chip with same package just below the battery connector.
    But even if i identify the ec i dont have a dump for that :/
    What can i do?
    your ecbios 2mb looks stranger, not completed file
    try with this, please confiirm working or not..
    U366-w25q16 2mb ecbios
    U365-w25q128 16mb mainbios
    goodluck
    • Elsid79
      • Aug 2015
      • 47
      • Ukraine
      I reflashed the Winbond chip using the HP Elitebook 820 G1 file.
      Flashing was no problem but it still tells me:
      "USER ID: BIOS Administrator
      Enter Password"
      I cant get in
      Try it https://bios-pw.org/
      • silversweden
        • 8
        • sweden
        goodluck
        U365: W25Q128 = 16MB
        U366: W25Q16 = 2MB
        U365: Detected as "M25P20S" by the CH341A software.
        I suspect its fried since i accidently put it in the wrong direction in the programmer...There was a green dot in the corner which i was thinking was the direction mark...
        But its marked 25Q12...cant read it completely because of the green dot...
        Now i need to scavenge a W25Q128 chip, i guess i just order one
        On top of that when i cleaned of the flux from the board a microscopic smd resistor/diode just popped of the board... cold solder...
        I managed to solder it back by using hot air but its so small that i cant even see if the solder is ok or not.
        When it goes wrong it really goes wrong
        • silversweden
          • 8
          • sweden
          Well i took a W25Q128 from another defect board i have.
          So flashing both U365 and U366 was done using the files from "rioreno".
          Now the computer wont even boot and i dont know if its the wrong programming to the chips or if i could not resolder the smd resistor/diode.
          (i guess its a 0402, really small)
          Thank you all for the help i really wanted this to work.
          Even bought a new screen for it since the old one was broken :/
          • snsent
            • Nov 2010
            • 103
            • Malaysia
            any SYSTEM DISABLE code appear?
            • silversweden
              • 8
              • sweden
              #26
              Hi, no not even a sign of life on the screen.
              The fan starts to spin and caps is blinking.
              Power led, thats all.
              • jasko_jacker
                • Oct 2014
                • 1140
                • italy
                #27
                To program this chip you use a clamp or desolder it and put them on programmer adaptor ? checks if all components ,around those chips, are in place.
                • basic
                  • Oct 2017
                  • 229
                  • 86357289244
                  #28
                  need urgent remove password hp 820 g1
                  hp 820 g1
                  pcid:A3009DD10303
                  • imranromi
                    • Jan 2015
                    • 1292
                    • Pakistan
                    #29
                    Re: need urgent remove password hp
                    Originally posted by basic
                    hp 820 g1
                    pcid:A3009DD10303
                    Here try this its working.
                    • basic
                      • Oct 2017
                      • 229
                      • 86357289244
                      #30
                      no display my friend and the fan is at max
                      • khaahk
                        • Dec 2013
                        • 833
                        • Estonia
                        #31
                        another version to try out:
                        • basic
                          • Oct 2017
                          • 229
                          • 86357289244
                          #32
                          also i have a question
                          do i need to program just 16 mb or i need to program both and 2 mb
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            #33
                            only 16mb for password issue
                            • imranromi
                              • Jan 2015
                              • 1292
                              • Pakistan
                              #34
                              hp 820 g1
                              pcid:A3009DD10303
                              Try this if same send service tag number.
                              • chipsetrepair
                                • Nov 2014
                                • 26
                                • Philipines
                                #35
                                Originally posted by Elsid79
                                Try it, dump is clear, from work notebook
                                HP Elitebook 820 G1
                                M/B 6050A2630701
                                128mbit
                                Hye there, file working perfectly. thank you so much.
                                • jakiko
                                  • Mar 2014
                                  • slovakia
                                  #36
                                  Hi, did you solve the problem? thnaks
                                  • sellit
                                    • Jun 2017
                                    • 105
                                    • Latvia
                                    #37
                                    Hi, I have Elitebook 820 G1 acting weird, it shuts off after few seconds, sometimes I managed to enter BIOS and reset it to defaults, but after restart again it turns off.
                                    Thinking maybe it's BIOS problem, can anyone could help fix my BIOS dump.
                                    • sellit
                                      • Jun 2017
                                      • 105
                                      • Latvia
                                      #38
                                      Hello, after re-soldering back my BIOS chips, laptop started to work correctly. Hope it's on long term.
                                      • jakiko
                                        • Mar 2014
                                        • slovakia
                                        #39
                                        HP Elitebook 820 G1
                                        M/B 6050A2630701
                                        128mbit
                                        It works , thanks
                                        • urgodfather
                                          • Jan 2019
                                          • 21
                                          • murica
                                          #40
                                          Just wondering, how are you dumping and restoring the SPI? Mazzif over at MDL has a nice thread on these systems. Using a pi and flashrom one could obtain a dump, download a clean bios update and compare the two. Flashing only the VSS styles area will retain the mac address of the nic. Im actually going to be doing this later today.
