HP Elitebook 820 G1 - Still BIOS password after flash
Re: HP Elitebook 820 G1 - Still BIOS password after flash
U366: W25Q16 = 2MB
U365: Detected as "M25P20S" by the CH341A software.
I suspect its fried since i accidently put it in the wrong direction in the programmer...There was a green dot in the corner which i was thinking was the direction mark...
But its marked 25Q12...cant read it completely because of the green dot...
Now i need to scavenge a W25Q128 chip, i guess i just order one
On top of that when i cleaned of the flux from the board a microscopic smd resistor/diode just popped of the board... cold solder...
I managed to solder it back by using hot air but its so small that i cant even see if the solder is ok or not.
When it goes wrong it really goes wrongLast edited by silversweden; 03-11-2017, 08:57 AM.Comment
Well i took a W25Q128 from another defect board i have.
So flashing both U365 and U366 was done using the files from "rioreno".
Now the computer wont even boot and i dont know if its the wrong programming to the chips or if i could not resolder the smd resistor/diode.
(i guess its a 0402, really small)
Thank you all for the help i really wanted this to work.
Even bought a new screen for it since the old one was broken :/Last edited by silversweden; 03-11-2017, 11:02 AM.Comment
To program this chip you use a clamp or desolder it and put them on programmer adaptor ? checks if all components ,around those chips, are in place.Comment
need urgent remove password hp 820 g1
hp 820 g1
pcid:A3009DD10303Attached FilesComment
Re: need urgent remove password hp
Here try this its working.Attached FilesComment
another version to try out:Attached FilesComment
Try this if same send service tag number.Attached FilesComment
Even bought a new screen for it since the old one was broken :/Comment
Hi, I have Elitebook 820 G1 acting weird, it shuts off after few seconds, sometimes I managed to enter BIOS and reset it to defaults, but after restart again it turns off.
Thinking maybe it's BIOS problem, can anyone could help fix my BIOS dump.Attached FilesComment
Just wondering, how are you dumping and restoring the SPI? Mazzif over at MDL has a nice thread on these systems. Using a pi and flashrom one could obtain a dump, download a clean bios update and compare the two. Flashing only the VSS styles area will retain the mac address of the nic. Im actually going to be doing this later today.Comment
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
by WutruHi guys,
If someone would be able to provide some expertise, I'd be very grateful.
BIOS Corruption - Cause
So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....-
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
- Loading...
