lenovo e440 bios dump
    • 22276
    Re: lenovo e440 bios dump
    Originally posted by andresi
    can some one do some patch this bios lock e440, thanks
    Try the lenovo Autopatcher, post the serial number ,read this - https://www.badcaps.net/forum/showthread.php?t=103570
    • Expired
      • Feb 2023
      • 34
      Try and reply with results
      • andresi
        • Nov 2020
        • 160
        • INDONESIA
        working perfectly thank you
        • Roy Buco
          • May 2024
          • philippine
          Thank you so much
          • AHmad_Salal
            Need BIOS Dump/ROM for Lenovo Thinkstation p500
            by AHmad_Salal
            Hello all,
            I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
            11-28-2023, 05:28 AM
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • hyperwood
            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
            by hyperwood
            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
            āœ… What I need:
            • A working 2MB BIOS dump
            • Matching NM-E471 Rev. 2.0, e.g. JY575
            06-25-2025, 02:28 PM
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
