lenovo e440 bios dump
    • 20446
    Re: lenovo e440 bios dump
    Originally posted by andresi
    can some one do some patch this bios lock e440, thanks
    Try the lenovo Autopatcher, post the serial number ,read this - https://www.badcaps.net/forum/showthread.php?t=103570
    • Expired
      • Feb 2023
      • 33
      Try and reply with results
      • andresi
        • Nov 2020
        • 151
        • INDONESIA
        working perfectly thank you
        • Roy Buco
          • May 2024
          • philippine
          Thank you so much
          • AHmad_Salal
            Need BIOS Dump/ROM for Lenovo Thinkstation p500
            by AHmad_Salal
            Hello all,
            I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
            11-28-2023, 05:28 AM
          • hyperwood
            [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
            by hyperwood
            I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
            The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
            I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
            āœ… What I need:
            • A working 2MB BIOS dump
            • Matching NM-E471 Rev. 2.0, e.g. JY575
            06-25-2025, 02:28 PM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • Joluvillas
            Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
            by Joluvillas
            Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
            06-18-2024, 10:35 PM
          • Captaincrap420
            Lenovo Tiny8 triple NVMe IQ6X0IL1 HQ670 NM-D581 Rev 0.5 M90q Gen 3 / P360 Tiny prototype board BIOS dump
            by Captaincrap420
            Hi, I hope this is the right place to post this. This is my first post on this forum.
            A friend helped me get a prototype Lenovo motherboard from China, it's got a hole drilled in it but I'm working on trying to revive it to some degree. I dumped the bios in hopes that it might be useful to someone, since this board is configured with the 3rd NVMe SSD slot and maybe it is useful as a reference for modding another bios to support this function. For example the M90q Gen 2 / P350's unpopulated 3rd NVMe slot footprint maybe.
            This bios dump is straight from the chip, nothing has been...
            11-29-2024, 05:40 PM
