[TUTORIAL] fix asus bios with bios from asus web support
+ More Options
Posts
  • Rhadu23
    • Mar 2021
    • 74
    • United Kingdom
    #41
    Re: [TUTORIAL] fix asus bios with bios from asus web support
    Very good to know.
    Thank you ! ! !
    • Mazorca
      • Jan 2017
      • 463
      Originally posted by razor_amd
      Lenovo can be tricky, but you often get everything in 1 file. I have written the tutorial on another website but pictures are gone . I wanted to re-post here but I have to do it again someday...
      Can you direct us to the website you posted that tutorial? We wish to learn. Or any helpful site with tutorials or guides.
      • minhduc18
        • Mar 2021
        • 32
        • viet nam
        #43
        i have model asus S330FA error bios,i download bios&firmware on asus driver but i can't extract biosregion. please example.
        • misterdray
          • Dec 2020
          • 5
          So basically we are replacing the main part of the update bios which should essentially be the same version bios with the one on the chip? I'm asking because I have been trying to do something similar as just flashing the bios from the website onto the chip makes the laptop not power on.
          • misterdray
            • Dec 2020
            • 5
            Originally posted by Mijgan
            Thanks a lot!!! Restored ASUS X542UA(M/B X542UQ Rev2.0) laptop, it locked bios admin password.
            I was wondering if this would work as well. Sounds worth a shot as I can always flash back original bios.
              • 20566
              Post your bios backup in a new thread in the Bios requests forum .
                • 20566
                Asus have started to include a Windows installer besides the normal updates. If there`s only a win update listed on the site the update can be extracted from the exe using innoextract . https://constexpr.org/innoextract/
                  • 20566
                  Originally posted by ala_borbe
                  hm, thank you for kindly sharing your methond... very usefull
                  anyway, i intended to cover other brands with tutorials (toshiba, acer, hp is very nasty, sometimes bios from web update are encrypted and i found 3 differen methods that work)
                  but stuff in life happened and im not in industry anymore, although im keeping an eye on forum it has grown on me
                  just as remark, maybe you should repost and make sticky so that it can be found easyer by other people since you have done such a wonderful job...
                  anyway, sorry for OT and keep up the good work mate
                  No problem, I found very useful info here and this is my way of repaying. It took me a while to make this tutorial but I am glad I did.
                  Anyway, this method can be used on all notebooks, not just ASUS, with others you just have to know what to look for inside BIOS Region. With HP there are BID's (BIOS ID), search it with Hex app and check which BIOS ID you have and need. Sometimes when extracting exe files from manufacturer website you will get only BIOS Region, sometimes ME Region as well with it in separate file and often there will be whole BIOS images. HP has ME regions in firmware section on their website, and I use those (newer) images when I build new BIOS.
                  For Acer it is mandatory to copy DMI, they wouldn't give image on screen if missing DMI data in BIOS Region. Toshiba is easy, maybe the easiest.
                  I copied your post and made it sticky,both your guides are excellent .
                  https://www.badcaps.net/forum/showthread.php?t=96604
                  • kalilinux25
                    • Mar 2018
                    • 2069
                    • ZAMBOANGA SIBUGAY
                    #49
                    is there a tutorial on acer bios editing?
                    • dam1inc
                      • Jan 2017
                      • 13
                      What about AMD devices. I have zenbook 14 with admin and can't find any info for removal. Thanks
                        • 20566
                        Off-topic. To answer your question, no it doesn`t seem so.You`re welcome to add your own tutorial though once you figure it out.
                        • aminealae
                          • Jun 2013
                          • 97
                          • morocco
                          #52
                          Thank you good job
                          • nikko404
                            • May 2022
                            • 7
                            • france
                            #53
                            thank you very much, my x555ln work now
                            • jiinbunk
                              • May 2017
                              • 5
                              • Zonguldak
                              #54
                              Thnaks
                              • matiasromoli
                                • Sep 2020
                                • Argentina
                                #55
                                The truth is that I had tried around 20 .bin files that I downloaded from several different places. I finally saw this post. My bios is 100% functional again. Thank you a thousand times.
                                • throwaway327
                                  by throwaway327
                                  Model No: RC72LA
                                  Serial No: SBNVKD001014459
                                  06-18-2025, 05:52 PM
                                • davidebeatrici
                                  Asus X541UV Windows update KB5063060 deleting BootOrder EFI environment variable? bios fix
                                  by davidebeatrici
                                  I had 3 people contact me in a week because Windows suddenly didn't boot:
                                  As you can see, all 3 are ASUS computers, but I believe the common factor is the BIOS being American Megatrends (AMIBIOS/APTIO).
                                  The first two recovered just fine after a restart, but the third one didn't and was brought to me. The model is F541UV (X541UV).
                                  Setup allows to add a boot option manually and the operating system boots just fine from both bootx64.efi and bootmgr.efi. However, there is no way whatsoever to save the option(s): upon a reboot the machine goes straight...
                                  06-17-2025, 12:59 PM
                                • jinki_dadou
                                  ASUS ExpertCenter D700MD need update bios
                                  by jinki_dadou
                                  helle
                                  in have asus desktop
                                  model : D700MD-5124000950
                                  CPU i5 12400
                                  I wanted to upgrade the processor i7 13700
                                  when I change the processor show black screen and fan spinning fast
                                  i ask asus technical support
                                  the answer : include microcode in the latest update bios
                                  he give me file 1 update bios
                                  2 microcode
                                  2 fils in tha attachments please help me
                                  ( sorry for my dab english )...
                                  05-18-2025, 02:20 AM
                                • mikeybass
                                  by mikeybass
                                  04-23-2025, 04:30 PM
                                • akwky
                                  by akwky
                                  Hi!
                                  04-14-2025, 01:56 PM
