Need Asus Bios Dump x550l
  • isidroco
    • Feb 2017
    • 7
    • Argentina
    Can't find a working bios for:
    Asus Model X550L
    Mother is x550lc rev. 2.0
    Thanks!
    PS: Is there a way to generate a valid dump from official Bios download? (Which is only 6mb instead of 8)
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    Re: Need Asus Bios Dump x550l
    here is
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      Asus Model X550L
      Thanks!
      read and post original bios, it can be "fixed" with that 6mb file
      Im Back... sort of...
      • isidroco
        • Feb 2017
        • 7
        • Argentina
        Thanks, I'd rather fix it myself, I have advance "rusty" assembler knowledge (Z80, 8088, hexeditors, etc). Any suggestion of how to do that?
        (Sometimes I use Araxis Merge and Hex editor XVI32 )
        Anyway will test first the one ridamouh159 sent and report back.
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          Only hex editor needed and uefi tool
          Download official bios, get rid of aptio capsule and rest paste in dump. Not hard at all but i write from phone, cant post link for tool
          • isidroco
            • Feb 2017
            • 7
            • Argentina
            Got PhoenixTool266 but not sure what to do next... If you can give a clue when you get home I would appreciate it, thanks!
            • isidroco
              • Feb 2017
              • 7
              • Argentina
              Unfortunately ridamouh159 dump didn't work.
              Mother is UMA, (without dedicated video chip)
              Original Bios dump is:
              http://www.mediafire.com/file/7w7jgg...ingoriginal.7z
              Here's a file drop to place the "fixed" bios:
              http://www.mediafire.com/filedrop/fi...cd6cfca58f8e30
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                see here
                i made small tutorial and how-to
                https://www.badcaps.net/forum/showthread.php?t=60659
                please wote if you find it usefull or not
                • isidroco
                  • Feb 2017
                  • 7
                  • Argentina
                  Thank you very much, downloaded two asus bios (x550l c with nvidia onboard and d without). "Fixed" original BIOS, but still black screen. Begining to suspect from the onboard ram.
                  Is there a way to disable it and try with a ram module on the slot?
                  • Nikich
                    • Jul 2017
                    • 6
                    • Belarus
                    Hi, need help with Asus x550lb. Motherboard asus x550lc rev. 2.0. What clock generator is there?
                    • lemevytas
                      • Aug 2016
                      • Lithuania
                      not working
                      • jhesy1230
                        • Apr 2018
                        • 7
                        • philippines
                        Originally posted by ridamouh159
                        here is
                        Working for me Philippines
                        • vedoza
                          • May 2015
                          • 37
                          • newyork
                          hi,
                          Asus x550lc Motherboard asus x550lc rev. 2.0. test ok
                          thank you so much
                          • zaido
                            • Sep 2017
                            • 20
                            • philippines
                            hi sir isidro i upload my non working bios to your filedrop. hoping you can fix it.
                            • neomarciuc
                              • Oct 2017
                              • 7
                              • România
                              here is
                              working bios.thank you
                              • mibo012
                                • Feb 2019
                                • 23
                                • Slovakia
                                Thanks ridamouh159 ,bios working
                                • pixi75
                                  • 82
                                  • Serbia
                                  works thanks
                                  • houcine17
                                    • Apr 2019
                                    • algeria
                                    here is
                                    Thank you very much, it worked
                                    • mad_dj
                                      • Jul 2018
                                      Thank you
                                      • tacorda1996
                                        • Jul 2018
                                        • philipines
                                        Thanks sir
                                        • mkdj
                                          by mkdj
                                          Dear all,
                                          10-19-2025, 04:41 AM
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • DynaxSC
                                          by DynaxSC
                                          06-14-2024, 03:49 PM
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
