Need Asus Bios Dump x550l
  • spiderman061
    • Nov 2020
    • 19
    • Türkiye
    Re: Need Asus Bios Dump x550l
    i need x550ln bios bin
    please someone help me
    • peste
      • 13924
      • ROMANIA
      post the original bios
      • Lisa Su
        Badcaps
        • Apr 2021
        • 216
        • Taiwan
        Try this
        • spiderman061
          • Nov 2020
          • 19
          • Türkiye
          Originally posted by Lisa Su
          Try this
          this file not bin file
          i need bin file
            • 22279
            i need bin file
            Rename the file from TEST.307 to bios.bin ,then it will be a bin file
            • mkdj
              by mkdj
              Dear all,
              10-19-2025, 04:41 AM
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • pirati
              by pirati
              10-27-2025, 04:20 PM
            • DynaxSC
              by DynaxSC
              06-14-2024, 03:49 PM
            • Ahari
              by Ahari
              I...
              08-13-2025, 06:12 AM
