Bios HP 840 g1 - 6050A2560201-MB-A03
  • Norag33
    replied
    Originally posted by ridamouh159
    Re: Bios and Schematic HP 840 g1 - 6050A2560201-MB-A03
    try with this
    It worked thanks
  • Jnmbc20
    replied
    Originally posted by hoaca388
    HP EliteBook 840 G1 Base Model Notebook PC
    Hello hoaca388, your BIOS powered and displayed but it got stuck at HP logo. I tried with different chips and the results were just the same.
  • hoaca388
    replied
    Originally posted by Jnmbc20
    SMDFlea Kindly if you can assist with cleaning the ME firmware, i would really appreciate. I dont know where i miss the turn, and I'm still reading bios ME clean guidlines between my tight schedules.
    Regards
  • Jnmbc20
    replied
    Thank you very much for your quick response. The dump worked! The only problem left is taking 15 seconds to display after power button press. There is a message: Warning!! Machine not in a committed state.
    How do i solve this? I have tried before to work with various NbDmiFit to modify serial numbers and commit a machine with no success.
    What is it that Iam not doing right?
    Will appreciate any help on that.
    Regards
    commented on 's reply
    Clean the ME firmware
  • Jnmbc20
    replied
    Originally posted by shiyab
    hi try
  • shiyab
    replied
    Hello all, I downloaded from this forum BIOS dump and flashed the above laptop which initially wasn't displaying anything. It worked, but after a couple of months it has started a strange problem.
    When I press the power button, it comes on but no display, I have to plug in the charger, then pull out, then plug it in again for it to display.
    I have included both BIOS and (I guess), EC dump for anyone with a know to look at it. Thanks in advance.
    S/n: 5CG5032N6V
    P/n: D8R83AV
    PCID: A3009DD10303
    MB: 6050A2560201-MB-A03
    hi try
  • peste
    merged post..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
  • Jnmbc20
    replied
    S/n: 5CG5032N6V
    P/n: D8R83AV
    PCID: A3009DD10303
    replied
    Originally posted by servicepcpascani@gmail.co
    Hello!
    I am also attaching a bios below that has a password.
    hp 840 g1 serial: cnu8309h9r / product: d1f44av
    can someone help me with this bios to remove the password?
    thanks
    Thread merged. You havn`t posted your backups but theres no need, try the HP unlocking tools, read the password guides
    BIOS guides, methods, resources and tools
    https://www.badcaps.net/forum/troubl...rces-and-tools
  • servicepcpascani@gmail.co
    replied
    Hello!
    thanks​
  • peste
    replied
    Originally posted by harryhirte
    Thanks for moving and sorry, still new to this forum...
    I think it's ok..you'll see along the way..on some HP and ASUS models, at the first start after rewriting the bios chip, they pass the DMI information from the I/O chip to the bios on their own..
  • harryhirte
    replied
  • peste
    post merged..next time look for a thread with the name and model, motherboard model,of the laptop and post there, if you can't find it, then make a new thread..
  • harryhirte
    replied
    With the help of this forum, I was able to restore an old HP Elitebook 840 G1 to life.
    What puzzles me a bit is that I did not need to enter all data into the bios-config utility to achive that.
    On the initial power-up after replacing the bios chips some scary warning appeared that this was attempt 1 of 10 (max?) and some data was missing or invalid.
    However, after a while the message disappeared and this message was displayed:
    EC MPM and System MPM Mismatch
    System needs to restore system information
    ... will take a few minutes...
    so after this the system boots up normally; I can boot an old win7 installation and proceed to
    the HP bios configuration utility.
    I did not have all the necessary information so I tried some settings (e.g. SKU, S/N, BUILID, FEATURE BYTE) I found here, but none of this was accepted.
    So I pretty much gave up and noticed that after several reboots and power cycles the system behaves normal.
    There is a S/N an SKU, but no Feature Byte or Build ID in the System information screen.
    I booted several linux distris (Debian, Ubuntu, Mint) and they work without hickups.
    So what is the story here?
    Is this system fixed or will I have an unpleasant surprise in the future?
    I can access all items in the BIOS menu and see no complaints about inconsistent settings.
    And the password (the original reason for the change) is gone as well.
    Can anybody shine some light on this?
  • markv81
    replied
    Originally posted by pticme
    Can you try this script (it's safe and very simple)?
    https://github.com/SpookySkeletons/h...os_unlocker.sh
    Does it lead to the same result (I mean hashes of unlocked files) as the tool you used?
    OK. I patched your dump with the script and it gives the following sha256 hash:
    Code:
    $ sha256sum N25Q128A-markv81-unlocked.bin
    a0f484d9bda83ae5578d6a0f8295edb5bd5457ae4629acbca003034f9059b319 N25Q128A-markv81-unlocked.bin​
    I will try flash my bios with it and check if it works. I hope your dump is correct, because I have the same n25q128a chip but it's broken so it seems I was unable to get the correct dump.
    Hi shiyab, thnx for your help. And does it work with you. best regards Markv81
  • shiyab
    replied
    Originally posted by Transalp
    Can someone remove the password from my dump of a HP Elitebook 840 G1? I tried with RCUnlocker but I get a message saying there is nothing to unlock. Thanks!
    backup file error
  • Transalp
    replied
  • pticme
    replied
    Originally posted by markv81
    Hello to all (hope this is the correct Elitebook 840 G1 Thread)
    Can someone help with a bios password unlock on the HP Elitebook 840 G1? after unlucking with hp unlocker i have a blinking power light white / orange.
    The chip is a Micron 25Q128A. Attached backup of the Chip and printscreen specs laptop.
    Model:HP Elitebook 840 G1
    SN: CNU4149HBD
    Thanks in advance
    Code:
  • poiler365
    replied
    board- 6050A2560201-MB-A03
    Serial -5CG5102VMM
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
  • haitham sharabati
    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
    by haitham sharabati
    Hello engineers 😀,
    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
    🔧 Device Info:
    - Model: HP 15-da2007ne
    - Product Number: 8XF55EA#ABV
    - Serial Number: CND0338P0D
    - CPU: Intel Celeron N4000
    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
    💀 Problem:😅
    - Device shows “Administrator Password”...
    08-07-2025, 04:54 AM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • DynaxSC
    by DynaxSC
    11-17-2023, 10:56 AM
  • MDSI
    HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
    by MDSI
    I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
    Details:
    Model : HP OMEN 17-an012nf
    Motherboard Part Number : DAG3BAMBAF0 REV : F
    Serial Number (S/N) : 5CD7280D51
    BIOS chip : Winbond W25Q64VSIQ
    Programmer : EZP2023+
    Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
    I already...
    07-28-2025, 07:11 AM
