dell m712h bios
  • asliyucegsm
    • Jun 2011
    • 351
    • Turkiye
    dell m712h bios
    my friend
    DA0VM9MB6A0 REV.A
    REV.A00
    PWA.M712H
    black screen
    bios dump and schema
    thanks
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: dell m712h bios
    here is a clean dump
    Im Back... sort of...
    • ravi_1617
      YY Solutions
      • Jan 2012
      • 350
      • India
      Dell Vostro 1088 DA0VM9MB6A0 REV:A
      Hi!
      This main board problem is ,Don't turn on. only 3.3 volt present.no 5 volt,when i press power switch. 5 volts comes,and 1.7 volt present at coil PL1 ,All Ready replaced MAX17020E. Worked for few hours fine. booted fine.Than same condition not on.
      • ravi_1617
        YY Solutions
        • Jan 2012
        • 350
        • India
        Re: dell m712h bios
        No one to reply
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • mikeybass
          by mikeybass
          04-23-2025, 04:30 PM
        • capoplays
          Help with BIOS update on Dell G15 5515 after chip replacement
          by capoplays
          Hey everyone,
          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
          When I check the BIOS using the F12 menu Flash...
          10-24-2025, 06:53 AM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • Sathsul
          Dell Latitude 5431 issues with dumping bios
          by Sathsul
          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
          10-28-2025, 07:49 AM
