Asus X301A Corrupted Bios
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hello all,
    I'm seaching someone that can fix 2 corrupted bios from 2 asus x301a.
    Motherboard : X401A rev 2.0
    I've found a dump, tested on 1 asus, was able to boot and reboot (using a Win7 hdd), re assembled and i got the same issue, turns ON with black screen
    I'm also searching a Dump if someone as one.
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    Re: Asus X301A Corrupted Bios
    this dump is ok i have tested it
    • passete
      Living=Sharing
      • Jun 2015
      • 487
      • France
      Many thanks Buddy,
      I've found one that is working with the 2 Asus X301A.
      Now i need to retreive the win 8 key on both of my dumps.
      • passete
        Living=Sharing
        • Jun 2015
        • 487
        • France
        I have tested this Bios and i confirm that it doesn't work with my 2 asus X301A.
        The one posted above from 1bios.ru is 100% Ok
        • polytek
          • Dec 2013
          • 496
          • TUNISIA
          the laptop is asus x301a-rx190h motherboard is : x401A rev 2.0 and it was ok after flash with this dump and it's returned to customer about 3 month ago.
          • polytek
            • Dec 2013
            • 496
            • TUNISIA
            and this is the original that i read from the board but no display:
            • passete
              Living=Sharing
              • Jun 2015
              • 487
              • France
              I can't explain the reason, i've read on others boards that some people was having problems with keyboard, same mobo version and revision, différents results.
              Anyway, the most important is that each of us found the solution !
              PS: i just tested your bios, because i was having issues with the touchpad, and finally the problem was the flex cable ...
              • polytek
                • Dec 2013
                • 496
                • TUNISIA
                [QUOTE=passete;659441]I can't explain the reason, i've read on others boards that some people was having problems with keyboard, same mobo version and revision, différents results.
                ok friends i understood you, i think the bios was not the same version, and the bios chip not identical, finally i'm glad that you fixed your laptop.
                • kazia
                  • May 2015
                  • 145
                  • indonesia
                  this the different, that's why it should post old dump,
                  it occurs in many asus
                  • polytek
                    • Dec 2013
                    • 496
                    • TUNISIA
                    thanks a lot friend for your time, have you a software for comparing buffer or just you do it manually like me ?
                    • bestdan50
                      • Aug 2015
                      • 170
                      • nigeria
                      what is the software for comparing buffer
                      • boskorp
                        • Sep 2019
                        • 8
                        This worked for me better than other dumps. KB working.
                        Laptop ASUS X301A-RX050D Board: X401A Rev:2.0
                        After flash with SPI programmer RT809F (chip WinBond W25Q64FV@SOIC8), updated to latest BIOS - X301A1AS213 from support site.
                        All fine, 10x
                        • lakrouf
                          • May 2015
                          • 12
                          • 84316327138
                          thanks is work for me
                          • lakrouf
                            • May 2015
                            • 12
                            • 84316327138
                            thanks polytek
                            • razor_amd
                              by razor_amd
                              12-15-2020, 07:07 PM
                            • DynaxSC
                              by DynaxSC
                              06-14-2024, 03:49 PM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • James194zt
                              Acer Nitro 50-640E Corrupted BIOS Dump
                              by James194zt
                              My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                              All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                              04-28-2025, 03:29 PM
                            • Anchar777
                              ASUS P1412CE need BIOS DUMP
                              by Anchar777
                              Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                              06-26-2025, 03:39 AM
