HP DV6-7005SP 48.4ST10.021 Goya Balen Bios Dump Needed
  • dmartins
    David M
    • Apr 2014
    • 197
    • Lisbon
    Hello , can someone give me a bios dump for HP DV6-7005SP ?
    Goya/Balen 1.0 DDR3
    11254-2
    48.4ST10.021
    Thanks in advance
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    Re: HP DV6-7005SP Bios Dump Needed
    You must try with this if is 8mb
    • mpikou
      • Jun 2013
      • 58
      • Greece
      HP dv7-7000ev Bios Dump
      I am looking for a HP dv7-7000ev Bios Dump, might anyone have it ?
      • yashjovi
        • Nov 2011
        • 130
        Re: HP dv7-7000ev Bios Dump
        try this
        • mpikou
          • Jun 2013
          • 58
          • Greece
          Originally posted by yashjovi
          try this
          HI,
          Thanks for the reply. I just tried, it didnt work...
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            MOBO Code???
            • mpikou
              • Jun 2013
              • 58
              • Greece
              MOBO Code???
              Goya/Balen 1.0 DDR3
              11254-2
              48.4ST10.021
              Might you need other numbers, near RAM slot's?
              Also tried this without results..
              • mpikou
                • Jun 2013
                • 58
                • Greece
                try this
                I tried again, after 3rd time the screen turned on, a bar with sad flashing loads and after that restart and posted as it should be !
                So, it seems to be working!
                Now, only i must do in to insert numbers or board etc.
                • mpikou
                  • Jun 2013
                  • 58
                  • Greece
                  I have HPBQ138 utility in order to save laptop board data.
                  But at this laptop i got the following message: "Hpbq138.exe This Utility Can not Be Executed On this Platform."
                  Might you know witch utility i must use ?
                  Just used that utility and it seems to work.
                  • mpikou
                    • Jun 2013
                    • 58
                    • Greece
                    I have updated all details, but when laptop starts, i got a message with invalid information:
                    System Board (00A) - Product configuration
                    The Serial, model, and System Board CT Number are 100% correct, and UUID auto generated..
                    Might is a known issue ?
                    • imranromi
                      • Jan 2015
                      • 1292
                      • Pakistan
                      send old bios i fix serial number etc....
                      • imranromi
                        • Jan 2015
                        • 1292
                        • Pakistan
                        if you try yashjovi bios ok i build bios add series number try and reply.
                        • mpikou
                          • Jun 2013
                          • 58
                          • Greece
                          Do you want me to send a backup of the bios i am using right now and all the numbers (serial, CT, etc) ?
                          • lebana
                            • Jan 2015
                            • 81
                            • sudy
                            Thank u
                            • charif
                              • Feb 2016
                              • 30
                              • agad
                              Thank you so much
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                Thank you, working great. Programmed board info with NBDmiFit and no error on startup.
                                A working TV? How boring!
                                • gcomputers
                                  • Apr 2013
                                  • 509
                                  • Albania
                                  hi im working with this model so BURNED first mosfet PU4006 Pchannel (replaced it) but mi mistake second mosfet is PU4004 also Pchannel on schematic but i replaced first all 2 mosfet (PU4004 and PU4006) without looking PU4004 is P or N channel. with N-channel PU4004 machine start Ok but problem is PU4006 to HOT. With PU4004 P channel i have 1v on output and machine not charge is normal with 1v.
                                  • gcomputers
                                    • Apr 2013
                                    • 509
                                    • Albania
                                    any idea?
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Voltage measurement on PU4004/4006 mosfets??
                                      • gcomputers
                                        • Apr 2013
                                        • 509
                                        • Albania
                                        with Nchannel pu4004 have 19v a D+S gate 24 so normall voltage and machinre start Ok but PU4006 warm to much
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • TacticalFahrrad
                                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                          by TacticalFahrrad
                                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                          06-30-2025, 04:09 AM
                                        • vinaypundith
                                          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                          by vinaypundith
                                          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                          So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                          08-03-2024, 12:32 PM
                                        • James Maxwell
                                          HP DM1-4000er Bios Dump needed
                                          by James Maxwell
                                          I badly need bios dump for HP DM1-4000er,
                                          Model: HP DM1-4000er
                                          Motherboard: DA0NM9MB6D0 REV.D
                                          Product: QJ490EA#ACB
                                          Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                                          10-28-2024, 05:38 PM
                                        • mkdj
                                          by mkdj
                                          Dear all,
                                          10-19-2025, 04:41 AM
