HP DV6-7005SP 48.4ST10.021 Goya Balen Bios Dump Needed
  • poweron
    • May 2019
    • 365
    • italy
    #41
    Re: HP DV6-7005SP 48.4ST10.021 Goya Balen Bios Dump Needed
    I did well?
    • Vesko356
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria πŸ‡§πŸ‡¬
      #42
      Originally posted by poweron
      I did well?
      No.
      Read SMDFlea's post carefully one more time.
      And after that read this tutorial too, will be useful for you. Same principle.
      Become a Badcaps supporter
      Thanks to all supporters.​
      • poweron
        • May 2019
        • 365
        • italy
        #43
        yes thank you, I have no experience in this regard, it will be hard to succeed
          • 20382
          The first picture posted with BID01818 is just showing your bios ID. Use the offsets in the second picture. In HxD close that "Editor Speciali" screen by clicking on the x ,it will only confuse you ,and closing it will give more screen space
          • poweron
            • May 2019
            • 365
            • italy
            #45
            let's see if I understand, I have to select the block in the old and in the new bios according to the offsets you posted then I have to copy the blue area of the old in the new then I am stuck, is that right?
              • 20382
              yes, copy from old,paste-insert into new using the same offsets
              • poweron
                • May 2019
                • 365
                • italy
                #47
                yes ok, once I have copied the old into the new one, can I save it and can I write it on the chip?
                  • 20382
                  yes.
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria πŸ‡§πŸ‡¬
                    #49
                    Yes of course, that's exactly the whole idea and the way it should be done.
                    • poweron
                      • May 2019
                      • 365
                      • italy
                      #50
                      ok, all this thanks to your precious help, but it remains for me to understand the reasoning to do to know on the basis of which criterion I choose one type of offset rather than others, would this operation be a reconstruction of the bios?
                      • poweron
                        • May 2019
                        • 365
                        • italy
                        #51
                        let's see if I passed the exam .... this should be the correct bios
                        give me confirmation so I write it on the chip
                        Thank you
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria πŸ‡§πŸ‡¬
                          #52
                          Different brands and models bios files are not the same, and of course the DMI information is located in different places, as well as the criteria for finding its location in the file.
                          And yes, it can be defined as a reconstruction of the bios, or more precisely adding the necessary specific information in it.
                          @SMDFlea I didn't notice your post, we answered almost simultaneously.
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria πŸ‡§πŸ‡¬
                            #53
                            Thank you
                            Great. Job well done!
                            • poweron
                              • May 2019
                              • 365
                              • italy
                              #54
                              thanks to you !!! .... without your contributions and tutorials it was unknown to me
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria πŸ‡§πŸ‡¬
                                #55
                                You're welcome. The excellently written tutorials are work of SMDFlea, so the credit goes entirely to him. I only helped further.
                                  • 20382
                                  Thanks for the kind words .
                                    • 20382
                                    You're welcome.
                                    • Vesko356
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria πŸ‡§πŸ‡¬
                                      #58
                                      My pleasure, good work should always be appreciated.
                                      Many see a job well done but few come forward with a word of appreciation.
                                      Cheers.
                                      • poweron
                                        • May 2019
                                        • 365
                                        • italy
                                        #59
                                        yes, I saw that it is the work of SMDFlea in fact I thank him for his competence and availability, I also thank you and the others who have helped, I take this opportunity to inform you that the notebook works perfectly thanks
                                        • poweron
                                          • May 2019
                                          • 365
                                          • italy
                                          #60
                                          Cheers.
                                          when someone dedicates time, which he could devote to other things, to help others solve a problem, free of charge, I would say it is right to at least thank him
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • vinaypundith
                                            Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                            by vinaypundith
                                            I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                            So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                            08-03-2024, 12:32 PM
                                          • James Maxwell
                                            HP DM1-4000er Bios Dump needed
                                            by James Maxwell
                                            I badly need bios dump for HP DM1-4000er,
                                            Model: HP DM1-4000er
                                            Motherboard: DA0NM9MB6D0 REV.D
                                            Product: QJ490EA#ACB
                                            Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                                            10-28-2024, 05:38 PM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • rednix01
                                            Nuc7i5BNH Bios Dump Needed
                                            by rednix01
                                            I accidentally bricked my NUC7i5BNH after disabling the option to boot from USB, and now it's not showing any display at all. I tried the USB recovery method, but unfortunately, it didn't work.
                                            Local repair shops are quoting around $150 just to flash the EEPROM, but considering the unit is only worth about $75 these days, that’s not really an option. So I'm hoping to learn how to flash the chip myself. But to get started, I need a working BIOS dump for the NUC7i5BNH.
                                            I did come across a post with a dump for the NUC7i7BNH, but I wasn't sure...
                                            06-19-2025, 06:37 PM
