Asus G75vw dump bios
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Hi
    I'm searching bios dump for asus g75vw rev 2.1 board , 8 MB in size.
    thanks
  • omerim41
    • Apr 2014
    • 4
    • turkey
    Re: Asus G75vw dump bios
    here some dumps my friend.
    one of mine old. others one of normal and one of modified dump.
    my laptop power on but doesnot show video on the screen. external vga working but system freezing on the windows screen. i try another windows setup but when i came disk volume selecting area freezing again. same result other dumps. i think hm chip damaged my own.
    regards
    • highpulse
      i hate HP
      • May 2013
      • 1488
      • portugal
      here it is
      • jasko_jacker
        • Oct 2014
        • 1137
        • italy
        regards
        On this laptop an Intel PCH damage is a common problem but first I would check (if possible) the entire system with intel processors diagnostic tool also available for linux
        • kimmy0312
          • Sep 2016
          • 12
          • Philippines
          do you have a full dumped bios of a g75vw with 3d display gtx 670m vga, with a custom bios support 2ndary for gtx 670mx??
          • Comrad_SU
            • Feb 2014
            • 31
            • Ukraine
            Originally posted by highpulse
            here it is
            Thank You Bro!
            • Rashid36
              • Aug 2014
              • 59
              • Saudi Arabia
              Dear Need Super IO Backup file it8517e
              Help Me out
              • peste
                • Dec 2016
                • 12776
                • ROMANIA
                Help Me out
                post the original bios of the laptop.
                • DanielDacko
                  • Mar 2015
                  • 325
                  • Macedonia
                  Help Me out
                  Not programmable I/0.
                  I don't provide help for people using CH341A and a clip.
                  • nassimhamdi
                    • Feb 2016
                    • 150
                    • algeria
                    thank you i will try -inshaallah-
                    • egis
                      • Feb 2020
                      • LT
                      attached a working G75VW modded bios to work with gtx 670mx (from g75vw)
                      Tested works great
                      • RJ554
                        • Mar 2023
                        • 6
                        • pakistan
                        sir please tell me how to flash this bios ?
                        i have asus G75vw and i buy a GTX 670MX but no display
                        • peste
                          • Dec 2016
                          • 12776
                          • ROMANIA
                          you need an SPI programmer...
                          https://www.youtube.com/watch?v=DWWigscuQDY
                          • RJ554
                            • Mar 2023
                            • 6
                            • pakistan
                            thenku soo mutch sir for responce..
                            Sir i go to my friends shop and burned the bios into laptop motherboard bios
                            but unfotunataley laptop lost to turning on nothing happens
                            • RJ554
                              • Mar 2023
                              • 6
                              • pakistan
                              this is my bios ..after a long time i got ch341a and revive my laptop ..so some please make this for GTX 670MX...
                              • RJ554
                                • Mar 2023
                                • 6
                                • pakistan
                                BIOS Modification Asus G75VW REV 2.4
                                need modified bios of G75VW rev 2.4 with gtx 670mx kelper
                                • RJ554
                                  • Mar 2023
                                  • 6
                                  • pakistan
                                  Asus g75vw bios issue
                                  hi guys . i have a serious issue .. Someone plz help
                                  i got Asus G75vw from a local person 3 month ago.
                                  and it was faulty From GPU .(Heat so much And shut down)
                                  I Replace the gpu GTX670MX instead of 670M and Mod the BIOS ..and that work...after a few day i thought to Overclock the gpu vbios .i installed a wrong bios mistakenly.and run pc ...so i got blackscreen..After that ..i even flash my backup bios.. doesn't get display .External monitor works..only display comes when GPU driver uninstall and reinstall display Shift External monitor to internal and gone when restart
                                  the problem is when i flash the bios ..and verify ..it says Sucsess..but after turning the Laptop on ..bios changes..again and again ��
                                  • RJ554
                                    • Mar 2023
                                    • 6
                                    • pakistan
                                    Help 🥺🥺🥺, asus g75vw bios blackscreen
                                    hi guys i have asus g75vw with gtx 670m ..1 month ago i changed the bios chip cus of death bios chip while programing...but after changin the ic the bios noting display on screen black screen but system is runing fine...vga works with ...when i uninstalling and reinstalling GPU driver...display came to internal screen wi
                                    orks fin before i restart ...and after resart ..display gone
                                    • MVV
                                      • Jul 2023
                                      • Poland
                                      This black screen while the whole system is working looks like a common issue for this model.
                                      Does anyone experienced to solve it somehow? Please feel free to share with us.
                                      While Im going to dig deeper
                                      • razor_amd
                                        by razor_amd
                                        12-15-2020, 07:07 PM
                                      • DynaxSC
                                        by DynaxSC
                                        06-14-2024, 03:49 PM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • Habble7
                                        by Habble7
                                        Suspected Cause:
                                        Troubleshooting Attempts:
                                        05-22-2025, 07:28 AM
                                      • Anchar777
                                        ASUS P1412CE need BIOS DUMP
                                        by Anchar777
                                        Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                                        06-26-2025, 03:39 AM
