asus x550jx rev.2.0 bios need
  • canali
    • Oct 2014
    • 189
    • turkey
    Re: asus x550jx rev.2.0 bios need
    thanks
    • guinie
      • Apr 2021
      • 11
      • Argentina
      Thank you!
      • yankogoshev
        • Mar 2018
        • Bulgaria
        For anyone that is still looking. This is a backup one from a working laptop.
        • pc.heidari
          • Apr 2020
          • 14
          • Iran
          asus k550jx bios need
          hi . asus k550jx motherboard x550jx rev 2.1 . all bios in forums no display on that board . please send me k550jx bios . i dont have org bios
          • peste
            • Dec 2016
            • 12274
            • ROMANIA
            Re: asus k550jx bios need
            post clear pictures with white or green stickers on the ram memory slot ..
            • pc.heidari
              • Apr 2020
              • 14
              • Iran
              #26
              jpeg
              • peste
                • Dec 2016
                • 12274
                • ROMANIA
                #27
                jpeg
                https://www.badcaps.net/forum/showthread.php?t=90309
                try post #2
                • kayitsiz
                  • May 2017
                  • 18
                  • istanbul
                  #28
                  Originally posted by amiga
                  this working and ok
                  thanks it really worked
                  • mcm022006
                    • Jan 2015
                    • 24
                    • romania
                    #29
                    hello! can someone help me repair this bios?
                      • 20339
                      See post 25 and 26 and post a picture of the sticker near the soldered ram.
                      • mcm022006
                        • Jan 2015
                        • 24
                        • romania
                        #31
                        here
                        • newarcada_computers@yahoo
                          • Jan 2019
                          • 25
                          • Romania
                          #32
                          its ok,thanks
                          • razor_amd
                            by razor_amd
                            12-15-2020, 07:07 PM
                          • throwaway327
                            by throwaway327
                            Model No: RC72LA
                            Serial No: SBNVKD001014459
                            06-18-2025, 05:52 PM
                          • jbonavita
                            by jbonavita
                            Some issues
                            Things I tried
                            04-29-2025, 09:38 PM
                          • lrouw84
                            by lrouw84
                            Hi there,
                            01-28-2023, 01:31 PM
                          • DynaxSC
                            by DynaxSC
                            06-14-2024, 03:49 PM
