Hp Probook 6545B bios dump wanted
  • Mario
    • Sep 2007
    • 64
    have a bios password locked hp. Does anyone have a bios dump?
  • imranromi
    • Jan 2015
    • 1290
    • Pakistan
    Re: Hp Probook 6545B bios dump wanted
    Try this.
    • Mario
      • Sep 2007
      • 64
      Thank you. worked very well
      • mike88
        • Sep 2016
        Hi - I have a Probook 6545b BIOS problem too. I tried to update it to the latest BIOS on HP's site.
        The update failed - the current bios is half working - boots operating system and grub but no keyboard input. The keyboard works fine in the bios set up screens and boot device selection - once boot device is selected and bootstrapped kbd no longer works.
        The problem is that the keyboard won't work once GRUB (Linux/Win10 dual boot) is started.
        I can access the BIOS setup screens - keyboard works fine...
        GRUB starts linux by default. the kernel reports: "Unable to enable ACPI" and " i8042 Can't reactivate KBD port"
        I have tried the "Windows Key + B" update from USB suggested by HP (Won't work)
        I have tried HPs "bootable" USB solution (would not boot)
        I used Rufus to make a bootable USB stick - copied HP " bootable" erompaq. exe, config.sys, and rom bin file.
        erompaq loaded but needs an F10 keypress to continue (KBD not working once freedos loads from USB stick)
        Tried filling KBD buffer with F10 keystrokes from BIOS setup boot selection screen before and during selection of usb stick as boot device.
        this started the rom update but then complained the machine needed to be on mains power (it was) - my guess is it is checking via ACPI if plugged in - corrupt bios has broken ACPI)
        Does anyone know of a bios rom flash software that can just update bios without checking acpi or needing user interaction (kbd not working under corrupt bios) that I can put on a usb that self boots and updates bios?
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          easier to get a cheap programmer and attack the spi flash directly.
          a clean dump is posted above.
          • devinetech
            • Jun 2017
            • Nigerian
            Pis, I need HP probook6455b bios dump.
            • imranromi
              • Jan 2015
              • 1290
              • Pakistan
              Originally posted by devinetech
              pis, i need hp probook6455b bios dump.
              old bios problem what?
              Send old bios.
              • Pascal Komlassan
                • Jan 2017
                • 809
                • TOGO
                Originally posted by imranromi
                Try this.
                thank's bro
                • newrolan2009
                  • Apr 2017
                  • 21
                  • BMW
                  Maney thankssssssssssssss
                  • okbalord
                    • Jun 2017
                    • 205
                    • Algeria
                    thx
                    OKBALORD
                    • Ahari
                      by Ahari
                      I...
                      08-13-2025, 06:12 AM
                    • mkdj
                      by mkdj
                      Dear all,
                      10-19-2025, 04:41 AM
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • studdy05
                      Bricked HP Probook 450 G7 Bios questions
                      by studdy05
                      Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                      Ive got...
                      07-08-2025, 09:24 PM
                    • haitham sharabati
                      by haitham sharabati
                      Hello engineers 😀,
                      🔧 Device Info:
                      - Model: HP 15-da2007ne
                      - Product Number: 8XF55EA#ABV
                      - Serial Number: CND0338P0D
                      - CPU: Intel Celeron N4000
                      💀 Problem:😅
                      08-07-2025, 04:54 AM
