Dell Bios Password For -1F66
    • 20966
    Re: Dell Bios Password For -1F66
    Originally posted by alijkd22
    Thx for your help but have tried this method but it didnt work
    i visited this website https://bios-pw.org/
    i tried this code jRB9tPxpZRO1K0rY many times but it didnt work i hope someone can give me a solution
    Note: The 6FF1 suffix has a bug,use your service tag with the BF97 suffix instead,Example: 1234ABC-BF97
    • alijkd22
      • May 2022
      • 4
      • algeria
      also i tried pressing ctrl+enter at the same time while entering the bios password
      • alijkd22
        • May 2022
        • 4
        • algeria
        can you plz send me the code sir cuz i tried every thing so far nothing works
        service tag 5BGYD72-1F66
        • miansh621
          Banned
          • May 2022
          • 133
          • pakistan
          hMbh2ryZ8G1zRbIr
          jRB9tPxpZRO1K0rY
          • questore
            • Dec 2015
            • 503
            • csongrád
            All of the above problems will be solved if you look carefuly at this page:
            https://en.wikipedia.org/wiki/QWERTY
            SOLUTION: The code given by https://bios-pw.org/ needs to be entered by QWERY keyboard layout and press CTRL+ENTER.
            REASON of this problem: Most of these servicetag laptops are made into latin2 keyboard where Z any Y keys are exchanged and most of the passwords contains therse charaters.
            • nain_uk
              • Jan 2015
              • 3
              • United Kingdom
              #26
              Help Please.
              99N4S32-1F66
              Following password doesn't work....
              3OzrZza64UXL102M
              • lapfix
                • Mar 2020
                • 2732
                • my workshop
                #27
                Originally posted by nain_uk
                Help Please.
                99N4S32-1F66
                3OzrZza64UXL102M
                https://www.badcaps.net/forum/showpo...3&postcount=21
                • jm801
                  Banned
                  • Apr 2020
                  • 123
                  • monterrey
                  #28
                  Can you help me with the master password for this dell #GBG1VZ1-1F66
                    • 20966
                    BIOS guides, methods, resources and tools
                    https://www.badcaps.net/forum/showthread.php?t=103526
                    https://web.archive.org/web/*/https://bios-pw.org/
                    • jm801
                      Banned
                      • Apr 2020
                      • 123
                      • monterrey
                      #30
                      Originally posted by SMDFlea
                      The page is not working, there is no other page because I don't have the equipment here with me, the client asked me if I had a master password, that's why I didn't reprogram it.
                        • 20966
                        working ok https://web.archive.org/web/*/https://bios-pw.org/
                        • jm801
                          Banned
                          • Apr 2020
                          • 123
                          • monterrey
                          #32
                          I tried it but it doesn't give me any password
                          • jm801
                            Banned
                            • Apr 2020
                            • 123
                            • monterrey
                            #33
                            Could you help me please
                              • 20966
                              It does generate a code as my picture proves.Also alisaler generates the same code
                              https://www.badcaps.net/forum/showpo...2&postcount=12
                              And if they aren`t working read the notes:
                              3.4. Dell
                              Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
                              See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
                              Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
                              Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
                              Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
                              Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
                              Note: There is no publicly available 8FC8 generator available at the moment.
                              The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
                              • mikeybass
                                by mikeybass
                                04-23-2025, 04:30 PM
                              • traxformania
                                TONGFANG "GM7TG7P" Bios Password Problem?
                                by traxformania
                                I tried :
                                -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                11-15-2023, 07:32 AM
                              • tlindi
                                Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                by tlindi
                                Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                Ack
                                Ack
                                01-30-2025, 04:26 AM
                              • Nopslide
                                by Nopslide
                                04-01-2024, 04:27 PM
