820-2936-b efi bios chip replace
  • opethfan
    • Feb 2015
    • 81
    • Italia
    hi, i have a macbook that requires efi pin password.
    so i do these actions:
    - desolder old efi chip (u6100)
    - solder a new one
    now when i power on the white led blink and it power off after one second
    - so i put the old efi chip but now i have the same result
    what i'm doing wrong?
  • rookieme
    • Oct 2014
    • 403
    • Greece
    Re: 820-2936-b efi bios chip replace
    Any chance you put it wrong direction?
    • dellxps15
      • Feb 2014
      • 1598
      • italy
      do fan spin for some times or just spin a bit and immediately shut down?
      without bios does it stay on ?
      looks like same problem i have with a macbook pro.
      • opethfan
        • Feb 2015
        • 81
        • Italia
        yes, fan spins for 3 seconds and then stops
        • dellxps15
          • Feb 2014
          • 1598
          • italy
          that aint great soldering. use hot air for desolder that kind of ocmponent and use good flux. plus clean whole part with ipa.
          so without bios it stay on for 3 seconds only ?
          • opethfan
            • Feb 2015
            • 81
            • Italia
            no, it won't stay on also without bios, but i found c6603 burnt...
            i hope that it is the problem...
            • opethfan
              • Feb 2015
              • 81
              • Italia
              replaced c6603 but same result...
              @dellxps15 i'm from italy too, can i send it to you?
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                macbook received and fixed
                have to check if efi password is removed, but should be fine. (put anothe rbios chip on it), but unfortunately one macbook hard drive i had is dead....
                • DynaxSC
                  ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                  by DynaxSC
                  Hi
                  I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                  08-04-2025, 12:20 PM
                  by SMDFlea
                  Bad...
                  09-02-2021, 04:40 PM
                • JoWed
                  Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                  by JoWed
                  Hello Community,
                  I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                  07-01-2025, 09:32 AM
                • hotcrossedbuns999
                  M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                  by hotcrossedbuns999
                  My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                  1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                  2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                  3. I could only locate two chips that look like bios chips. Could someone verify this
                  01-03-2025, 12:32 PM
                • capoplays
                  Help with BIOS update on Dell G15 5515 after chip replacement
                  by capoplays
                  Hey everyone,
                  I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                  The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                  When I check the BIOS using the F12 menu Flash...
                  10-24-2025, 06:53 AM
