Asus X551ma rev 2.0 bios dump please
  • ry x hunter
    • Jun 2013
    • 184
    • philippines
    hello guys.. i need help.. i need bios dump for asus x551ma rev. 2.0
    please help..thanks
  • naeemshahzad
    • Jan 2015
    • 129
    • uae
    Re: Asus X551ma rev 2.0 bios dump please
    here is the dump
    • alihomee
      • Dec 2012
      • 1565
      • malaysia
      hi shahzad did u tried bios .....any results post here
      • naeemshahzad
        • Jan 2015
        • 129
        • uae
        This is Tested bios
        • samuelnagy
          • Feb 2017
          • 14
          • Egypt
          thank you i will try this file
          • Shamsi
            • Oct 2015
            • 31
            • india
            thank you
            • ormcra
              • Jan 2016
              • 14
              • madrid
              I tested and work fine!
              Thanks.
              • kemal1380
                • Jul 2017
                • hatay
                thanks
                • zurvanielle
                  • Feb 2017
                  • 137
                  • Philippines
                  Thanks... It works..... ^_~
                  • dnzdnz
                    • Feb 2015
                    • 9
                    • turkey
                    hello it works wind x551ma rev 2.0
                    • sultano91
                      Laptop fix
                      • Aug 2017
                      • 10
                      • turkey
                      can anyone share the x551ma rev 2.0 EC dump
                      • caneskicakit
                        • May 2017
                        • Türkiye
                        original copy i have
                        • crunsch0
                          • Dec 2012
                          • Badajoz
                          muchisimas gracias bios funciona OK !!!!
                          • rakibul85
                            • Mar 2017
                            • 26
                            • Bangladesh
                            thankssssssssss shahzad
                            • KrishaYea
                              • Sep 2016
                              • 4
                              • Latvija
                              Thanks weary much!
                              I checked old, dead dump - bios date was from 04/10/2014, this one is from 04/15/2015. A lot of EC FW updates between, but still it worked. Notebook started fine, but display color is a bit off, hard to tell - it's bad cable or EC.
                              Could it be bad EC instructions?
                              Probably stupid question, i'm new to this..
                              • KrishaYea
                                • Sep 2016
                                • 4
                                • Latvija
                                Problem was software related..
                                • livan.calcedo
                                  • Feb 2020
                                  • cuba
                                  • iyori20
                                    Banned
                                    • Nov 2018
                                    • 43
                                    • maroc
                                    thank you
                                    • pcnetwork
                                      • Jan 2021
                                      • 29
                                      • Venezuela
                                      Originally posted by naeemshahzad
                                      here is the dump
                                      Thanks for the help
                                      • ezzeddin
                                        • Feb 2019
                                        • 16
                                        • syria
                                        [QUOTE=ry x hunter;623354]hello guys.. i need help.. i need bios dump for asus x551ma rev. 2.0
                                        please help.
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • DynaxSC
                                          by DynaxSC
                                          06-14-2024, 03:49 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • kcp0085
                                          Request BIOS dump for ASUS FA617NS-A16.R77600
                                          by kcp0085
                                          Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
                                          I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
                                          Specs:
                                          - ASUS TUF FA617NS-A16
                                          - CPU: AMD Ryzen 7
                                          - BIOS chip: Winbond W25Q16JVSIQ (2MB)
                                          If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
                                          Thanks in advance!​
                                          05-02-2025, 12:52 AM
