Asus X551ma rev 2.0 bios dump please
  • peste
    • 13924
    • ROMANIA
    Re: Asus X551ma rev 2.0 bios dump please
    [QUOTE=ezzeddin;1262616]
    Originally posted by ry x hunter
    hello guys.. i need help.. i need bios dump for asus x551ma rev. 2.0
    please help.
    • mberbouch
      • May 2014
      • 109
      • Morocco
      here is the dump
      Thanks, for this dump it work for me too.
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • pirati
        by pirati
        10-27-2025, 04:20 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
