Hp elitebook 2540p Locked
 Re: Hp elitebook 2540p Locked
 Perfectly working
 cheers!Attached FilesLast edited by dahnking; 05-27-2019, 09:58 AM.Comment
			by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
 Model No: RC72LA
 Serial No: SBNVKD001014459
 I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
							Channel: BIOS Requests ONLY!
			by q2v5Lenovo T480s
 Model 20L8-S3TE00
 Board ET481-U10
 Chip MX25L12873F
 Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
 2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
 The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...-
		 by GuestHello, by GuestHello,
 I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
 I assume the BIOS update failed, so I searched for the BIOS chip.
 I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
 However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
 Can the corrupted...-
			by NeddsmeHie.
 I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
 Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
 I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
 I managed to run Windows troubleshooting and...-
			by Max029I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
 I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
 TY,
- Loading...
