Hp elitebook 2540p Locked
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: Hp elitebook 2540p Locked
    Originally posted by idrazutra
    Hi There, i will tell you, how i did to this to work.
    First you need to get the Serial Number and UUID by pressing F1 on Boot Menu, write for use on the HP EliteBook Tool that the user (imranromi) provided
    1)Remove Hard Drive from Laptop
    2) Try to boot by network
    3)Insert the USB formated and with the tools provided above
    4)Follow the Instrucctions from http://mazzifsoftware.blogspot.com/p...os-unlock.html
    5)Thats all.
    Not support new model.
    • hussaka
      • Jan 2015
      • 152
      • italy
      thank you very much
      • razu
        • Jan 2015
        • 218
        • Bangladesh
        Originally posted by imranromi
        COMPAL LA-5251P REV 1.0
        working dump try this.
        Yess friend your bios is 100% okkkkkkkkkk....Thanks for attach.....
        • quic307
          • Jun 2015
          • 255
          • Greece
          Hello, friends.
          I have the eliebook 2540p.
          I want to install the PN, SN ect with DMI tool.
          What DMI brand I must use ...
          Thank you in advance...
          • imranromi
            • Jan 2015
            • 1288
            • Pakistan
            Originally posted by quic307
            Hello, friends.
            Post here old bios without dmi data.
            • quic307
              • Jun 2015
              • 255
              • Greece
              #26
              I want to use the DMI tool without to programming the chipset.
              Because I bought the MB and it in warranty.
              I can read it and I can edit it but I want "clean job".
              • dahnking
                • Apr 2018
                • 257
                • kenya
                #27
                Perfectly working
                cheers!
                • keyzen
                  • Feb 2022
                  • usa
                  #28
                  hey so im new here and wanted to know how to dumb/flash bios
                  • throwaway327
                    by throwaway327
                    Model No: RC72LA
                    Serial No: SBNVKD001014459
                    06-18-2025, 05:52 PM
                  • q2v5
                    Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                    by q2v5
                    Lenovo T480s
                    Model 20L8-S3TE00
                    Board ET481-U10
                    Chip MX25L12873F
                    Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                    2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                    The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                    08-15-2024, 10:40 PM
                  • Guest
                    Elitebook 850 G5 BIOS bricked
                    by Guest
                    I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                    I assume the BIOS update failed, so I searched for the BIOS chip.
                    I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                    However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                    Can the corrupted...
                    03-24-2025, 01:21 AM
                  • Neddsme
                    Bios partially corrupted somehow and now warm boot doesn't work which is critical
                    by Neddsme
                    Hie.
                    I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
                    Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
                    I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
                    I managed to run Windows troubleshooting and...
                    02-04-2022, 05:57 AM
                  • Max029
                    Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
                    by Max029
                    I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
                    I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
                    TY,
                    08-18-2024, 08:28 PM
